Question about Hunter Dryers
How do you put back together a hunter table top fan model 90022
SOURCE: need a hunter westside2 model #21621 instructions w/ pictures
Costco.com has an online manual for this fan. That is the same model number you are looking for.
Posted on Jun 13, 2009
  • 497 Answers
SOURCE: How do I take my Hunter Model 20723 model fan down
there are a couple of bolts that hold the housing on, after removing the blades you should see more mounting bolts that attach to the ceiling....fyi disconnect power First!
Posted on Nov 06, 2009
  • 57 Answers
SOURCE: Hi , I have inherented a Hunter Table Fan 90023
Howdy,
It's highly possible the Capacitor has failed. The motor in this fan is Permanent Split Capacitor.
Do the blades spin freely? If you bump them around, do they coast, or stop suddenly? If they coast freely then that would point towards the capacitor. I believe Hunter has a 5 year warranty( it may be 1 year) on these fans, so it may still be under warranty and they may send you a new unit. Their phone# is 1-901-745-9222.
If it is the Capacitor, it is possible to replace it and to find out if it is the capacitor, remove the rear motor cover (should be one screw on the rear of the motor cover) there will be a small box, most likely black, or yellow with some writing on it, if it looks swollen up or melted, this is obviously the problem. However, depending on the failure mode, it may not have any visible indication that it has failed. If it has failed and you wish to repair the fan, Hunter should be able to send you a Capacitor and all you need to do is clip the wires on the old Capacitor and connect the new capacitor to those wires. Just make sure the wires are secured, it's very simple, you can do it yourself.
Posted on Dec 23, 2010
  • 122 Answers
SOURCE: I just installed this royal
yes there is a diod in the fan its like a fuse but smaller if you open the modules in the fan you may see a diod burnt or dicolered this does happen alot these control differnt parts of the fan light fan itself, good luck
Posted on Aug 06, 2011
vanillaki768
  • 89 Answers
SOURCE: How to put together a fan
Hope this helps. http://www.reviewstream.com/reviews/?p=100785
Posted on Jul 01, 2013
How do I program a Hunter 44250A Thermostat
Randall, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hunter 44200 Owner Manual Table Of Contents
http://www.hunterfan.com/supportdocuments/ownersmanuals/44200.pdf
http://www.hunterfan.com/Support
Hunter Fan 44250 Manual
Jun 01, 2016 | Hunter Dryers
Open clean
Send it back to Hunter!!! Should be under warranty.
Oct 18, 2013 | Hunter 90021 Century Table Fan
I bought at Target a Hunter table fan, out of box, with slide control at bottom. It will not turn on. Is there a trick to this or is it broken.
Try a different outlet in case it is an issue with your house wiring. Otherwise, take it back to Target. There are no tricks to making it work.
Sep 18, 2011 | Hunter Dryers
I just installed this royal oak hunter fan model number 23668 last weekend. It worked great until yesterday when it would not come on. I checked power to the fan and it was there. I took it back a part to...
Aug 06, 2011 | Hunter Fan The Royal Oak 23688 Ceiling Fan
Howdy,
Dec 21, 2010 | Hunter 90021 Century Table Fan
4 month old Hunter 52". After install, when you turned on the tulip lights that came with it, they would come on bright, then dim about 20%. Recently, when the light was turned on, they would blink...
Your problem is you are using too much wattage for your fan. You can solve this one of two ways. Put in lower wattage light bulbs (per your manufacturer recommendations) The other is to remove the wattage governor. There should be 3 screws holding your light assembly on. Remove these screws then disconnect the white rectangular plug in connector (this is what connects the fan wiring to the light assembly wiring). At this point you should be free to take the light assembly to a table. Follow the light pull chain wires from inside. One of these wires will lead to a black box that has 1 black wire, 1 red wire and 2 white wires. Remove this black box...this is the wattage governor. Remove by cutting the 2 white wires as close to the box as you can, peel back the insulation and use a wire nut to connect the 2 white wires together. Remove the wire nut on the black wire from the switch to this black box. Now you have one red wire left and your bare black wire from the switch. You will remove the red wire and put the bare black wire from the switch in it's place. Throw the wattage regulator in the trash and install you light assembly back to the fan. It will no longer blink but you should still use the recommended wattage light bulbs to prevent overheating.
Aug 19, 2010 | Hunter (25417) Ceiling Fan
Glass replacement for Hunter fan
Hi, hunter fan glass replacement can be found at amazon, take a look here and chose: Amazon com hunter fan glass replacement. Regards. Donald
Jul 10, 2009 | Dryers
Remote not working fan...
You can get them a Home Depot. You may have to buy the receiver and the remote together.
May 25, 2009 | Hunter Ceiling Fan Remote Receiver...
Need a hunter westside2 model #21621 instructions w/ pictures
Mar 17, 2009 | Hunter Dryers
Dryers Logo
37 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
