How do i get my inside antenna to work. - Televison & Video
    Master:
  • 623 Answers
Be sure the "source" selection is "Antenna". You should find a button on your remote control labeled "source".
Posted on Nov 29, 2014
Where is antenna for radio
It is the top[ lines in the rear glass. If you look close, you can see the separation. Most new window tints are metallic, and ruin the antenna, I made sure they didn't tint the antenna on my 2003 Civic. Any aftermarket antenna will work, the antenna cable coming out of the radio is just like any other.
Sep 22, 2014 | 2004 Honda Civic
1992 camry antenna does not come up
from the inside of the car where antenna is mounted it bolts out relatively easily ,an aftermarket replacement Universal antenae is available ,your local car sound shop can help advise you ,pulling it up is difficuilt as there is gears and electric motor involved ,car sound shop can fit an antennae electronic box on inside of your windscreen that works far more efficientlt than the standard unit
Jan 15, 2014 | Toyota Cars & Trucks
Mazda antenna 6 broken how to fix
replace the antenna, or if its in the windshield, replace the windshield. You can buy an aftermarket antenna that will work, only thing is where you decide to mount it. Mounting nut for antenna is inside fender, and you have to reach up there at base of antenna to loosen and remove it.
Dec 19, 2013 | Cars & Trucks
I CAN ONLY RECEIVE 2 OR 3 RADIO CHANNELS ON MY INSIGNIA RECEIVER
Radio tuners receiving AM and FM channels/broadcast MUST have some sort of antenna connection. For local channels a paper clip will work, but for more distant channels, use either a better inside antenna or purchase a outside antenna as needed.
Jan 30, 2013 | Insignia 200W Stereo Receiver
Proview 3200 wont work w/ outside antenna
I don't think it has ATSC tuner at all. In other words I don;t think it will work with an inside antenna either.
or if it does...just use the inside one :-)
Oct 01, 2012 | Proview Televison & Video
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
My radio antennae does not work. I hear a
the cable inside that moves the antennae is broken. on many models you can just replace the antennae with cable instead of the entire unit whick will be a lower cost. ask at the volvo dealer.
May 15, 2010 | 1995 Volvo 850
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Air ware xm2go
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Jul 03, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Antenna
that's because the mechanism on the inside of the electric antenna in detached from the actual antenna and will run till it manages to read that it has gone down . simple solution is to cap off one of the power wires so it stops as it will need to be replaced to work again any way, the only wire you need to leave is the antenna wire in the middle (or the biggest one there) and it will still work as you do not need a power supply to run the antenna.
Jun 04, 2008 | 1994 Cadillac Seville
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
