Question about ASUS Computers & Internet
HOW DO I SETUP A SCSI CARD AND SCSI HARD DRIVE ON AN ASUS A8R-MX/S MOBO
  • 3,368 Answers
Read the instructions that came with the card and drive that should get you going. O if it is microsoft you may have to install aditional drivers.
Posted on Nov 29, 2014
map9966
  • 2351 Answers
SOURCE: asus P4GE-MX
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Posted on Jan 16, 2008
  • 6 Answers
SOURCE: Asus TXP4 Motherboard will not turn on
Most likely you are looking at a bad motherboard, there is probably a break somewhere in the connections. Check for blown capicators that would be a smoking gun. You can use a different motherboard but it has to be one that is compatible with your CPU. Most motherboards will come with a driver CD so you should be ok. It shouldn't be a big deal with your Operating System or Hard Drive if you replaced your motherboard. Otherwise, you could upgrade to a new system and do a image copy of your HDD to a new computer/HDD. I recommend Acronis True Image makes it really easy.
Posted on May 11, 2008
SOURCE: asus p4p800-x no screen no beep
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Posted on Aug 04, 2008
  • 312 Answers
SOURCE: I need lan drivers for the ASUS A8R-MX motherboard
please find your driver in the below link...
http://www.driverstock.com/RealTek-Network-drivers/18-28/index.html
Hope this will help you...Thank you...
Posted on Oct 21, 2009
SOURCE: Missing Motherboard cd
i have no cd of driver plz.send asus a8v-mx driver.
processor-AMD Athlon 64
Posted on Oct 27, 2010
I need the manual for an Asus A8R-MX/S motherboard. Any idea where I can get one?
Here is the ASUS support website: http://support.asus.com/download/download.aspx?SLanguage=en-us
You might be able to find the manual there.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | ASUS A8R-MX/SI Motherboard
ASUS A8R-MX/SI Motherboard drivers
Aug 22, 2010 | ASUS A8R-MX/SI Motherboard
Hi, cannot find the right set of drivers for the mobo A7N8X Deluxe. It does not recognise my SATA drive, even I've installed corresponding drivers After pressing the F6 key and installing the SCSI Drivers...
Connect your SATA on the first SATA slot to make it as the Master. Or maybe the BIOS settings is set only to recognize IDE device. If this is the case, try going to BIOS settings then Peripheral Devices, look for the menu Hard Drive and replace the IDE into SATA.
Feb 04, 2010 | ASUS A7N8X Motherboard
How do I reactivate my onboard video on my mobo ? (Asus A8V-MX-UAYKZ)
It will automatically be activated if you remove your Graphic Card
Sep 21, 2009 | ASUS K8V-MX Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
PCI.SYS corrupt?
Do you have any kind of pci card that was or still is connected to the mobo ?
Jan 30, 2008 | ASUS P5VD2-MX SE Motherboard
Computers & Internet Logo
5,341 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
