Question about 2006 Mercedes-Benz C-Class - Coupe - Base Rack System
Remove the plastic trim from the inside of the tailgate of a Mercedes c class coupe
  • 55 Answers
Pleas go and join one of the mercedes forums its free you only have to register .I am in 6 forums, then you and ask your question and you will have a member help you .
Posted on Dec 25, 2014
Remove the osr door lock on a mercedes c200 class (w204).
You have the loom connection and a bar down from the door handle which has a plastic clip on it ,been a while since i done a merc one ,done a new focus last week ---- what a job unlike the older models it was rivited to the window channel and i had to remove the whole lot ,big screwdriver and broke the plastic clips so i could get the whole unit out ,bit of two pack epoxy adhesive to repair the plastic and out it went again ,
Feb 10, 2015 | Mercedes-Benz C-Class Cars & Trucks
We need help on trying to get the wind deflector up so we can work on the windshield
You have to remove the sunvisors and rain sensor cover & the side trims + upper plastic roof trim there are hidden screws behind the rubber trim on the top section and 4 screws beneath the interior upper plastic section thats why you need to remove the sunvisors etc, it will lift off reasonably easy once all the screws are removed be careful with the plastic pieces I did this job last week takes about 45 mins to remove
Dec 12, 2014 | 2014 Mercedes-Benz E-Class
My 1996 s320 front right window is broken. How do I get access to it?
Hello and welcome to FixYa!
Please perform the following to gain access to the window motor.
- Remove the door trims, they are secured by plastic snaps so you will just have to pull them off carefully, be sure to look if there are little screws that needs to be removed. - Once you removed the door trims, carefully remove the connectors of the power windows behind the door trim to pull it out thoroughly. - Remove the plastic that's covers the door frame. - You will need a 10mm socket to remove the glass and motor that mounts to the door frame - You may now replace the power window motor and do the procedure vise versa on installation.
Hope this helps and thank you for using FixYa! Have a good one!
Jul 24, 2011 | 1996 Mercedes-Benz Mercedes Benz S Class...
I am replacing the tailgate strut that failed and can't get the trim cover off to snap out the bottom of the strut.
In the lift gate inside trim panel you will see a plastic cap plug at the door latch area. Remove the plug to gain access to the latch.You will see the plastic plug cap at the bottom of the inside lift gate trim panel. ----------- Click this link below for more details:--- http://technoanswers.blogspot.com/2011/07/how-to-remove-tailgate-strut-on.html --------- This should help.Thanks.Helpmech.
Jul 20, 2011 | 2006 Cadillac SRX
Where i can support a filter for aircondition for mercedes e210
IN your car don't have A/C dust filter only have charcoal filter, open under trim panel of dash at passenger foot well have look in you can see two covers lock by sliding plastic lock, slide the plastic lock to open and remove charcoal filters.
Oct 05, 2010 | 1999 Mercedes-Benz E-Class
How do you remove front door trim on E220
Pull trim from inside area of mirrors. Remove plastic from around door handles and seat switches. Remove screw from end door clip. Remove bolt from under door handle plastic. Unscrew lock knob. Pop tabs from bottom of door by pulling then lift up and wiggle door. Glass felt may or may not come off with panel.
Sep 24, 2010 | 1995 Mercedes-Benz E-Class
How do you remove Tailgate interior PANEL on Ford Freestar 2004 tailgate door
Remove the 2 bolts from handle, #2 from picture. Remove 2 screws from either side of door pane(#4) now just the clips hold it on, pull panel off at one corner and work your way around until its completely removed.
Thank you and good luck,
Lee
Jun 03, 2010 | 2004 Ford Freestar
How to open front door in Mitsubishi lancer.
Try to remove interior trim (plastic) on rear door panel from inside the vehicle to access metal access panel and get to door actuator rods to get door open for further repair.
Mar 10, 2010 | 2000 Mercedes-Benz S-Class
Can't open tailgait on 2002 Mitsubishi Montero.
I have the same problem with a 2001 Mitusbishi Montero XLS. Door handle is stuck and feels mushy when trying to open it. Is there a safety from the inside panel to open the cargo door? At this point, until its repaired, all I want to do is to be able to release the lock and open the door.
Sep 29, 2009 | 2002 Mitsubishi Montero
I need to remove 2004 toyota sequoia tailgate door panel to get access the rear tail light to install a backup camera. I don't see any obvious removal points.
Slide the plastic cover off the tailgate ******** the passenger side to reveal a 10mm bolt.
Remove the bolt and the strap/
Using a flat prying instrument, remove the center trim section one the inside of the tailgate above the window.
Grab the top edges of the side trim sections on the inside of the tailgate and pull down to remove.
Using a flat instrument, pry at the bottom edge of the tailgate main trim panel, it is held on with about 12 plastic pop-in fasteners so it will take several 'pops' before it is released.
Behind that there is a metal access cover the width of the tailgate, held on by ~5x pop in fasteners and ~10x 10 mm bolts. Remove the bolts and pop the panel loose, it will hang by the wiring so support it while you do your camera work :)
The license plate trim panel, should you need to remove it, requires remoaval of the license plate.
Then remove ~3x 10mm bolts from the top of the panel, accessed from the inside.
Using long needle nose pliers compress the pop-fasteners holding the lower corners of the license plate trim panel on, being careful not to let it drop and slide down the vehicle, scratching the paint :)
Sep 20, 2009 | 2003 Toyota Sequoia
2006 Mercedes-Benz C-Class - Coupe - Base Rack System Logo
211 people viewed this question
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
