Question about TYC 02-05 03 04 Kia Sedona 3.5l V6 Cooling Fan Assembly In Box 2004 2005
I have 02 kia sedona that runs rough at idle nd dies when i put it in gear and give it gas.
Last time i drove it it was sputtering real bad and dieing when i drove it. pumped the gas pedal repaetedly to get it to restart. then it died and woldnt start. although it would keep trying then it had a real strong odor in car after that that i cant explain. left it sit for month or so and went to tinker with it. vanstarted and was running at idle but if i give it gas it seams to want to cut out if i let of and pump it it will rev up to limit. when i put it in to gear it runs worse and will die if i keep giving it gas. but if i put it back in gear it will stay running. havent checked code will do that tommarow. step dad who use to work on cars thinks it sonds like it may need a tune up. any ideas
  • 2 more comments
  • terrance
    terrance Dec 16, 2014
    just hooked the scan tool up throwing p0122 two times on same scan and p0102. which is throttle /pedel position sensor circuit a low volt and mass air circuit a low voltage
  • willy15 Dec 16, 2014
    I told you how to check the fuel pressure on this vehicle, did you do it? Is so, post the pressure.If not, do it please. Also did you change your fuel filter?
  • terrance
    no didnt check fuel pressure. cant find the post where you told me how to do that. nd havent changed the filter. its been in the single digits here. nd its broke down half hour from where i usually work on it. but since ive posted ive had it running twice sofar it will sit at idle nd run as long as i let it. once half hour nd today 45 mins. without dieing unless i put it in gear nd give it gas thats when it dies. did put three front spark in front. nd new coil over boots. havent taken air pheluam off yet to change the back three. but only codes are for the tps/pedal position switch
  • terrance
    terrance Dec 17, 2014
    also i was told the 02 kia sedona does not have external fuel filter its attached to fuel pump nd if i try to take it off i will damage fuel pump so should i just order a new fuel pump nd be done with it i can get a new one for under a hundered bucks nd change it in 20 mins. but i will atleast check fuel presser
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 114 Answers
Hi!
In my opinion:
1.) fuel filter
2.) spark plugs (change, or clean if clogged)
3.) fuel pump (hope not, this is quite expensive)
Hope I could help. Try it, 1.) + 2.) are not more than 50 bucks + 20 to 60 minutes, depending how experienced you are...
Posted on Nov 29, 2014
Testimonial: "the funny thing is the fuel pump is easier to get at then the rear spark plugs it has a access panel right behind the front seats. lift the door pull 4 screws and its right there. have to take air fauluam off just to get to rear plugs. thanks for advice."
    Master:
  • 706 Answers
Do the simple thing first, change the fuel filter, if that doesn't fix it, then you'll have to check fuel pressure to make sure it's in spec.
Posted on Nov 28, 2014
Testimonial: "not sure how to check fuel pressure. cant check it at the rail. tried that last weekend. kia didnt put a nozzle on the rail."
  • 8 more comments
  • willy15 Dec 02, 2014
    If it has not port, then you'll have to disconnect and go thorugh the fuel high pressure side. When you unhook it, there will be residual fuel pressure, just put a shop towel over it so it doen't spray you. You should have an adapter in your fuel pressure check kit to fit the end.
    I just noticed you said it had a code stored. What is the code?
  • terrance
    yes po122 which was on there twice for same scan and po102. po122 is throttle/ pedel position circuit a low current and po102 mas air circuit a low current.nd week ago went nd it started nd ran rough at idle for half hour. but when i gave it gas it would almost cut immediately but if i let of nd give it gas i could get it to rev limit. but in gear itwould run worse nd die if i gave it gas nd would run at idle agian after that. also it shifts down out of 4th into 3rd. so i just drove in 3rd for few months. then reverse went out. code said under drive slinoid vale system any ideas hear its limp home mode. fluid is browner red not the bright red. was told flush would correctthat. any ideas
    First change the fuel filter, then you need to check fuel pressure. If you don't have the tools to check the fuel pressure, you'll have to take it to a shop. After you've done both, then we'll move on to the codes.
  • terrance
    k i will figure out where fuel filter is nd get that changed tommarow or next day. a
  • willy15 Dec 17, 2014
    The reason for this, is I stongly believe your issue is fuel related. Please let me know when the filter and pressure have been checked.
  • terrance
    i also wanted to add that i went over there today nd tried stsrting put but it wouldnt even try to pop nd start like it normally does so i pulled out the sparkplug
    Your commment was cut off. Was there any fuel on the plug you pulled or was it wet with fuel?
  • terrance
    and it was soaked with fuel and i noticed the boot under the coil over is i can see carbon marks from where the spark is jumping so im also gonna change those. also i has a bad battery in it so ive had jumper cables hooked to intrying to start it could those codes be from bad battery? but i will figure how to test fuel presser and put fuel filter in it nd get back to you. also got few questions on transmission problem but i will wait nd see if inget it running agian. i think it may be in limp mode but not sure i can tear apart nd replace anything been working on cars over 15 years just not the best at diagnostic
    If your battery is bad or has low voltage, nothing works and it will through various codes. Put your DVOM on the battery and make sure you have at least 12.8 Volts without it started. If not you're battery needs charging completely before proceding.
My 03 kia sedona starts up and will idle for 30 or 40 minutes and die out ad start up again and run a few more minutes nd die again then not start for a few hours
Change the fuel filter and see it that helps. It sounds like a fuel supply problem, and the filter is the least expensive most likely place to start.
Jan 08, 2018 | 2003 Kia Sedona
Car will start but put it in gear engine will die
engine starts with no problem; but, when I put in gear and ...
www.cargurus.com > Questions > Hyundai > Sonata
CarGurusNov 15, 2012 - The engine just fall dead when you step on the gas; it seems to jerk before ... My car does the same thing but i put it in neutral n it starts up. ... I have a 2004 kia optima it jerks when I go into reverse it was driving ... start and run fine butwhen I put it in drive or any other gear it dies! ... 2002 Hyundai Elantra GT.
Engine stalls when tranny put in Drive or Reverse - Kia Forum
www.kia-forums.com/kia-carnival...2002.../43407-engine-stalls-when-tr...
Feb 28, 2008 - 10 posts - ‎3 authors
Give it a little gas before putting in D or R and it will go. .... When I start the van cold and shift the tranny into drive or reverse.....the whole front ... won't run in forward gears - Kia Forum
May 25, 2012
Intriguing problem - engine rough idle & hesitation ...
Aug 31, 2011
2006 Kia Spectra engine stalls and bad idle, cleaning the ...
Aug 30, 2010
2002 Kia Spectra Won't Go Out of Park - Kia Forum
Oct 28, 2008
More results from www.kia-forums.com
Dec 17, 2015 | 2002 Kia Rio
My 2002 kia sedona won't idle until warms up, dies when put into gear ...any ideas??
Is the check engine light on? you could have a bad ignition fail sensor, TPS sensor, or bad o2 sensor. it could also be a bad mass air flow sensor or a vacuum leak. without a code to help pin point the problem I'd start by checking those things first. Maybe try unplugging the mass airflow sensor and start it up and see if anything changes.
Oct 03, 2014 | 2002 Kia Sedona
Van sputters when you put it in gear after its been started multiple times
Bad fuel pump, stopped up fuel filter, mabey? First check for vacume leaks.... may try unplugging the throttle position sensor. Plug it right back in... just check the connection.
Aug 02, 2017 | 2002 Kia Sedona
Truck sputters and doesnt have power at lower rpms
Possible fuel pump about to die. They will work if revs kept up
Aug 12, 2012 | 1990 Isuzu Pickup
4.3 L will not idel
check the Idle Stop Solenoid
May 22, 2010 | 1992 GMC Safari
Kia sedona 2002 smell gas in the interior of car
Sounds like you might have bad O2 sensors, leaking fuel injector O rings or a bad fuel pressure regulator. Check that the vacuum hose to the pressure regulator is connected and no cracks or holes in it. Any check engine light?
Jan 07, 2010 | 2002 Kia Sedona
I have a 02 kia sportage and it dies on 1st start,nocodes,realwea
Repace the mass air flow meter.Its those symtoms it gives when it failes
Jul 18, 2009 | 2002 Kia Sportage
My girlfriend has a 93 olds cutlass ciera and it dies in reverse
When is the last time she had a tune up?
I would start there. Plugs, Wires, Distributor Cap and Rotor. Hope this helps you and thank you for using FixYa!
Mar 26, 2009 | 1993 Oldsmobile Cutlass Ciera
1991 Geo Metro Automatic/ Sputters, runs rough only in gear.
Could possible be a bad or stuck vaccum advantace mechanism. Check for operation.
Feb 16, 2009 | 1991 Geo Metro
TYC 02-05 03 04 Kia Sedona 3.5l V6 Cooling Fan Assembly In Box 2004 2005 Logo
168 people viewed this question
Top TYC Computers & Internet Experts
jeff5may32
Stan Ford
Are you a TYC Computer and Internet Expert? Answer questions, earn points and help others
