Question about Car Audio & Video
How to fade speakers from front to back on jvc kw-xr610
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Found instructions PDF: http://resources.jvc.com/Resources/00/01/50/GET0665-001A.pdf
Posted on Dec 01, 2014
  • Timothy Greene Dec 01, 2014
    Thanks Lorenza for your help.
  • Lorenza McCants
    Lorenza McCants Dec 01, 2014
    You're most welcome.
Not sure where to plug my amp in on back of my head unit it's has multiple rca jacks on the back... It's a jvc kw-av61
Run the speaker wires from the stereo to the amplifier high outputs, or get a converter fr your stereo speakers wires to rca, most older amps have a high output witch have a left +-, Right +- depends on how many channels your amp is..
Oct 25, 2016 | JVC Car Audio & Video
Problem with JVC Kw-xr610 Car CD / USB/ MP3 Player Cd player works and volume control all other buttons won't
Have a tech open the ftont cover and check for cracked board. This board cracks when pushing the volume control too hard
Sep 28, 2013 | JVC Kw-xr610 Car CD / USB/ MP3 Player
Jvc shorted out while installing
Unfortuneately that will mean the audio output transistors and ic's have been compromised in the receiver, I suggest an assessment.
May 02, 2012 | JVC Kw-xr610 Double-din Usb/cd Receiver W/...
I have seen broken board inside. Have you ever pushed the front panel? If so, the board behind the control is cracked. If you are a tech, open and solder. If not, take it to a service center
Mar 07, 2012 | JVC Kw-xr610 Car CD / USB/ MP3 Player
Jvc dvd cd player 3in monter
Was it working before?
If so, (a) fade control is not in the center or (b) Unit or speaker is broken
If it never worked, then check wiring
Jan 27, 2010 | JVC KD-AVX1 Car DVD Player
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
Size of speakers and amp recomendation for JVC KW-AVX800
you need to find out what size speakers you have now and upgrade them with that size the amp you get will be based on the rms rating of the speaker. Example if the speakers rms rating is 100 watts the get a amp that puts out between 100 and 120 watts rms also to add bass you could go with a subwoofer that will add all your low freq. If you want something that doesn't take up alot of room try a bass tube you can get one amplifed or not.
Good Luck
Jun 23, 2008 | JVC KW-AVX800 CD Player
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
