Question about Globe Food Mixers
How do i repair a an electrical problem on an sp8 globe mixer.its not turning on i replaced the main circuit board the reset switch. i dont know what else could go wrong.
5 Suggested Answers
  • 20 Answers
SOURCE: Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
Posted on Jun 11, 2009
  • 130 Answers
SOURCE: runs wide open then quits
Looking at the parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204551.pdf
find item 9. It is a hall effect sensor which measures the speed of the motor and feeds back that info to the controller - if it is open or shorted the motor will not be controlled and will either not run at all or run wide open.
Posted on Mar 30, 2010
  • 185 Answers
SOURCE: KitchenAid KSM90 mixer wont turn on, already replaced phase board
Did you play with the Brushes??? If you did you have to make sure that they went back in the correct way or they won't be touching the armature and the mixer will not operate untill the brushes touch the armature. If you did nit take the brushes out at all. then your problem is the flag connectors are not in the correct terminals. 9_15_2012_6_02_40_am.jpg
the other problem is the possibility that when you re-installed the speed board that you now have to tune the mixer by adjusting the screws on the top of the speed board.
Posted on Sep 15, 2012
SOURCE: Well, I was attempting to replace my speed lever.
I re-adjusted the springs/carbon and it still won't turn on. That's the only thing I did so not sure why it won't turn on. Help?? Thanks
Posted on Aug 15, 2014
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
Where can I fix a circuit board in Spain or UK
I'm sorry but that sounds like a total loss. International power stanarf is 220v but US is only 120v. Likely all electronic circuitry is burned out. It would be cheaper to get it replaced since the board, motors and anything else electric will need to be replaced. Next tome get an international adapter that dials down 220v to 120v if you order anything else from US.
Apr 28, 2014 | KitchenAid KP26M1XPK - Professional 600...
I replaced one of the control handle that simply had the black knob broken off. Kitchen aid mixer was working perfectly up to then. When I put it all back together it won't turn on at all! I touched n
There should be a Micro switch that is plugged out or broken,you will find this switch on the arm if it dont connect or make contact the machine will not work.There will be 2 wires on the switch will be small becareful can break easy.
Jan 06, 2014 | Food Mixers
Kitchenaid mixer works intermentily
How old is the mixer? If older, check for possible short in cord either at plug end or at mixer body. Best to disassemble and test cord with VOM meter. Often cord and break internally and show open circuit only when cord bent a an angle.
Next< i would look at the speed mixing switch, the mechanical part, not the electronic board, for defect such as dirty contacts.
If above do not work, then check motor brushes. And, only then I would suspect electronic controller.
Please psot Mixer model and serial number rfor further assistance
j
Nov 29, 2013 | Food Mixers
Hi, Our Indian made Preethi Eco Chef mixer had stopped working after pressing the overload button repeatedly, any idea whether any repair centers in and around Ipswich
Hi, please replace the Overload button (Circuit Breaker) with a new one. You can purchase the Overload protector (Circuit breaker) in any nearby Mixer repair or Electrical shop. Please take the old Overload protector to get the new one of same specification which suits for your Mixer.
Apr 16, 2011 | Food Mixers
My Sunbeam Heritage MixMaster mixer just stopped running while making cake frosting. Is there a reset button anywhere?
If it is plugged into a circuit protected by a GFCI breaker, which it should be if it is a kitchen circuit, reset the breaker. If you know for sure there is power at the receptacle you have it plugged into, then the power cord is bad or you have an internal mixer problem. You will have to pay someone to repair it or take the mixer apart yourself and find out what is wrong. Before paying someone be sure and get an estimate as to the cost of the repair. In some cases you are better off buying an new mixer as the repair costs will exceed to price of a new one.
Dec 18, 2009 | Sunbeam 2346 Heritage MixMaster Series...
It acts as if there is no power.
no safety interlock but it may be the speed adjuster. This is accessed by rear cover and turning small centre screw while powered up. Note electrical shock hazard. If in doubt return to appliance repairer.
Sep 11, 2009 | Food Mixers
Mixer switch is locked
If this is a 325 watt Artisan, there is no safety switch I know of unless its in the circuit board. Your mixer is broke.
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mixer just won't turn on -speed control jammed
Unplug the appliance. Take it to a well ventilated area and spray some alcohol in the slot where the switch is while trying to move it. This must be done with the appliance unplugged and the appliance must be thourughly dry when you plug it in. Use canned air or if you have one a compressor.
Mar 05, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Motor is not running now
Im a service tech for hobart and repair these mixers often-is it worth repairing the unit?YES it is.I have never seen a motor burn up on these units,i have seen keys sheared and gears broken but thats the extent.There is a overload/reset button that sits on the back of the mixers pedistal,if its tripped when you push it in it will click.when these units need service it is usually from overloading the unit with too much product.Any other questions let me know.
Nov 30, 2007 | Hobart N50 Stand Mixer
Food Mixers Logo
Top Globe Food Mixers Experts
eyecam
Are you a Globe Food Mixer Expert? Answer questions, earn points and help others
