How do i get to pictres
Preety art project
    New Friend:
    Problem Solver:
  • 6 Answers
Try a google or bing search under images
Posted on Nov 29, 2014
My preeti lavender stopped workng suddenly
If its new, I would return it for warranty.
Dec 31, 2012 | KitchenAid ProLine 600 Stand Mixer
Have sound but onl see top of pictre and is blinking with a humming sound in back of tv
You have bad grounds on the power supply board. There will be many of these on the bottom of this main board. The board I speak of has a large black transformer with two red wires coming out of it. When you pull this board out, inspect the underside for bad solder grounds. There may be some bad capacitors. Cl004 (25 volt 1 Mf) is bad. CLO23,( 25 volts at 1Mfs) is bad. CP150 (16 volts at 2200Mf) ,CP140 (16 volts at 1000Mf) and CP120 (50 volts at 220 Mfs) should be replaced.Oh yes! CL36 which is a 250 volt at 2.2Mfs is bad, replace this as well. The clues in this info should give you a fix. It is quite challenging to remove repair and replace this board. With patience it can be done! Thanks for asking and show all hands of support.
Oct 15, 2011 | RCA D52W19 52" Rear Projection Television
The picture blinks black foe a sec. then back to normal pictre it has a 5times flash on the stanby bulb. book says akb?
5 blinks indicates faulty on c board (CRT base board) often a loose solder connection on RGB output amplifier.
Jan 11, 2011 | Sony Televison & Video
Art Tube MP Project Series preamp how to set up comp to record
USB option does not work at all q as they said....Their use manual only makes marketing...It is not nice.
if I ask simple step by step. What is problem with it?
I fed up to use USB option ( no rec signal ) on this unit cause I have been told, better to use Yamaha mix device....
best.
V.
Sep 29, 2009 | Dual ART DPS II Preamp System with Tube...
My red s off in my pictre causing ghostng
you will need to replace both convergence ICs they are both STK392-120 and you will also need about four 6.8 ohm 1watt resistors as well. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Jul 28, 2008 | Philips 60PP9202 60" Rear Projection...
Hi preeti
Which Country are you looking for?
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Lines in every pictre ,
Many compact digitals (of all brands) use a Sony sensor and Sony had a bad batch go through and the sensor's contacts are failing.  If you are getting images corrupted with lines, bad/weird colour or severe noisy hash, you may well have a dud sensor.  Check the canon web site for a list of effected cameras and/or contact Canon service.
Canon is replacing effected sensors free of charge regardless of warranty status.
Jan 31, 2008 | Canon PowerShot S2 IS Digital Camera
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Toshiba 42H81 Red Vertical bar on right side
The symptom suggest a faulty converge ic.you need to replace that ic ( stk392-110 ).
Aug 06, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
