Question about Proscan 26LB30QD 26 in. LCD HDTV
Click on botton, blue lite comes on and inmediatly turns off
    Novelist:
  • 167 Answers
Your diagnostic circuit is detecting a problem somewhere in the set and shutting it down to protect the remaining good circuits. Check the power board for fault it is usually the culprit. Look for capacitors with spewed up tops. They may also be leaking a oily like substance (electrolyte) and when replaced will fix it. If not then your problem could in many places. Look at the power board first and see if the voltages are coming off it if the capacitors are OK.
If not then nothing else on the board can be fixed. You will have to order another. If I can help with anything please feel free to contact me anytime.
Col. Dana Gillespie
Posted on Nov 29, 2014
My right front turn signal on my 1997 fordf250 truck will come on but will not blink. I have replaced the bulb and bulb socket but it did not help. What could be my problem?
The other turn signals front and rear work ok? Disconnect right turn signal, with that signal turned on, use a test lite on the white wire with lite blue tracer, does the test lite pulse?
Does the right turn indicator on the dash pulse on and off?
May 26, 2017 | Cars & Trucks
Is Blue Lite For High Beam Supposed T oStay on when clicked?
To clarify, when you pull the turn signal lever towards you, the high beam lights will come on only as long as you hold the lever up. This is the flash to pass feature.
To switch the headlights from low beam to high beam, you push down on the lever towards the dash. Then the high beam lights and the blue indicator light should stay on.
Jun 09, 2013 | Cars & Trucks
I have a toshiba 32hl66 no pic and no sound. when the blue lite is on i t won't responed to the remote.and I can't. Ok when I. Turn on the set a yellow lite/blinks 3 times and the blue lite will...
This is a classic switchmode power supply, has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
Oct 11, 2011 | Televison & Video
Repair questions
My name is Con Brewer- I just replaced the Combination SwitCh on my 1989 Lincoln Town Car! They told me my Hi Beam Lite(Small Blue Lite on dash)should stay on when I clicked it on. It desn't! Also , I turned key on,before I put plastic cover back on steering column to Check new combination Sw. It did did not ("lite did not) stay on new switch.When I covered steering column,I had no BATTERY AT All NOT EVEN A Click .I can't get Insp. Sticker Without lite. Help -Please.q
Oct 22, 2010 | Pontiac Firebird Cars & Trucks
DSTT card wont load in DS Lite
have you got moonshell try reloading with all the games becase i have a ds lite and that works
May 03, 2009 | Nintendo DS Lite Console
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
Flat screen trouble
May sound like the video board went out.
Sep 10, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Polaroid 37" lcd hdtv flk3732
I would say you need to have a Control box replaced it is a simple install.
May 22, 2008 | Polaroid 4226TLMB 42 in. LCD TV
L and R bottons
try cleaning them if nomal cleaning doesnt work spray a quik shot of wd-40. NOTE just a tap to loosen the gunk in the side of both buttons and let sit for an hour come back and press the button multiple times. NOTE:do not use very much pressure or you may further damage
Oct 28, 2007 | Nintendo DS Lite Console
Proscan 26LB30QD 26 in. LCD HDTV Logo
67 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
