Question about Mtd Garden
I need a routing diagram for the deck belt on a MTD Yardman HN5180 Hydro
This lawn tractor was left from the old owners of the house, and it all works except the deck belt is not on it. I have the belt and it look in good condition but cannot work out how it goes on. It seems far too long!
  • Mtd Master
  • 1,169 Answers
Try this site just needs to determine if is one or the tow idler system. The tow idler system is a lot more complex on routing the belt.
HN5180
Posted on Nov 28, 2014
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
lester482529
  • 226 Answers
SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Posted on Jul 03, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How do you replace deck belt for craftsman lawn tractor 917.276680
Here is a link to the owners manual which has the belt routing diagram.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0606052.pdf
Aug 30, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I put a genuine factory parts deck drive belt O.E. 954-04062/754-04062 on 38"Bolen's lawn tractor model#13AM762F765
To start with, the easiest way is to remove the mowing deck from the tractor. It will really be tough if you don't or can't. You may need an owners manual to guide you through all the steps.
1. Remove the cutting deck from the tractor 2. Work the old belt off (if not broken) the mandrel pulleys and idler pulleys 3. Pull the belt away to reinstall a new one 1. Work the new belt around both the mandrel pulleys 2. Make sure the belt is in all the pulley grooves and inside all the belt guides 3. Now you have to reinstall the mowing deck. Here are some diagrams that should help you.
http://www.ereplacementparts.com/bolens-13am762f765-2005-lawn-tractor-parts-c-27272_27390_27402.html
Apr 19, 2011 | Garden
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I'm replacing the mandrel housing on the deck. the new housing has no threads in it. Can i tap threads and use regular bolts to mount housing to deck.
The old bolts in the old spindle should be self-tapping. Put a little oil on them and screw them into the spindle. Otherwise, yes, you can tap them and use any good quality grade 5 bolt.
Sep 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need diagram of deck belt installation
May I get the make and model # to get you the right belt diagram
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
How do you change the deck belt of a 48in 21 hp husquvarna tractor
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532426477.pdf
Go to the above link and you can download a very good manual for it. It shows the routing of the belts as well as a lot of other useful information
Sep 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Large belt routing for crafstman lawn tractor
Jul 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
142 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
