Question about Husqvarna Garden
MY GT2254 HUSQVARNA TRACTOR WON'T CHARGE. I HAVE TO CHARGE BATTERY BEFORE EACH USE.
ONE DAY IT CHARGED AND THE NEXT DAY IT DIDN'T AND HASN'T SINCE THEN (ALL SUMMER). I HAVE TO CHARGE BATTERY BEFORE EACH USE. I CUT 3 ACRES AND THE BATTERY LAST BUT DURING THAT TIME IT DOESN'T CHARGE. MY ENGINE IS A BRIGGS AND STRATTON 22 HP.
    Master:
  • 706 Answers
Put your meter on the battery and see what voltage it's putting out while running and post the voltage for me. Then I can answer your question.
Posted on Nov 28, 2014
brado83
  • 106 Answers
SOURCE: Mower Runs briefly then cuts out and wont restart.
These ride-ons have a cut out solinoid under the carby that when there is no power or the ign is cut it will drive a little pin into the main jet to prevent flooding, id say this is why your mower runs for 20 and stops...
There is a few reasons this could be occuring:
#1First I would be checking the battery see if its dropped a cell or has a dead cell, you can do this by load testing it with a load tester or removing it and taking it into a battery specialist. if this is the case the battery will not accept a charge from the charging circuit...
#2 Check your wiring with a multimeter from the armature under the flywheel all the way back to your battery (also these models may have a regulator/rectifier that can be tested they have test values and can be checked by your local small engine repaier)
#3 If all your wiring is ok then you will have a problem with your armature this is located under the flywheel on your engine it has two seperate windings one for the charging of your battery and the other powers your headlights / elec magnetic clutch, the one for the charging will be unservicable these can be diffucult to access and test and is probably best done at your local small engine repair shop...
Hope this helps you out
Kind Regards
Brad
Posted on Jan 01, 2010
  • 15 Answers
SOURCE: tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Posted on Mar 25, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
  • 6468 Answers
SOURCE: part number for a Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT belt
try sears parts online
Posted on Mar 29, 2012
  • 2239 Answers
SOURCE: battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
Posted on May 06, 2012
About once every 2 to 3 weeks car won't start. Battery appears dead. Then next day fine. Battery holding charge, not starter either. Baffe
If the battery appears dead when the fault occurs, it probably is the battery (or pos/neg leads) batteries are devious and take pleasure in appearing fully charged. Eliminate further by replacing battery, buy or borrow. Only other explanation is a short to negative on particular day, check starter motor cables. Best of luck.
Mar 13, 2015 | 2007 Honda CR-V
Have a problem with my car chevy van g20 the battery is new and the alternater the car runs all day but when the next day comes the battery is dies and i have to charge the battery help with some idea
You have something draining power that should be switched off, or a short to ground in the wiring. If you disconnect the battery it will probably still be charged in the morning.
Someone would need to pull fuses and disconnect components to find the power drain while watching the battery with a meter.
Jan 24, 2014 | 1986 Chevrolet G20
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
I have a 1988 camry and i charged my battery a day ago snd tryed to start it again the next day and it was dead again. Do i need a new battery?
It definitely sounds like the battery has had its day. Unhook the battery from the vehicle, charge it....leave it unhooked over night, and attach next day.... if the battery has life, it could be an accessory in the car is taking the power. if not, replace battery
Oct 25, 2012 | Cars & Trucks
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
Was driving home it was 35 below had to boost car be for i left work drove 30 miles when the car just quit next day charged battey full charge but it will not stay charged is it the alternator or the...
It's a possible combination of both. A bad battery won't ever hold a charge and a drive of 30 miles should have charged the battery sufficiently to start the next day. Since the car would run once jumped, the alternator appears to be doing it's job but without having it tested (most auto parts chains will perform this test free of charge) it's impossible to tell whether it's putting out enough amperage to adequately to charge the battery.
Dec 20, 2009 | Honda Civic Cars & Trucks
ENGINE CRANKS BUT WONT TURN OVER
you meant its a NO CRANK engine.
silent starter, say the word silent.
even the starter relay must click.
and if head lamps die, so will be the starter.
due to a dead battery,
sounds like a bad battery to me. dead or only
DISCHARGED.
if the Charge/battery lamp is off in the cluster driving. its ok. the alternator.
starter car with the jumper cables connected
and not next day.
only live jumps matter. or you go know where.
if you want to walmart they have tool there that
tests the alternator
battery
and for phantom drains all in 6 min work, the tool does all the work.
if the battery is charged, it will crank I bet
its discharging.
for 1 of 3 reasons.
1: its bad.
2: the charge system is dead.
3: phantom drains, it goes dead as you sleep
the head lamps dead is the big clue there.
Mar 19, 2017 | 2002 Jeep Grand Cherokee
Garden Logo
356 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
