Question about Kenmore Washing Machines
My kenmore series 500 washer automatically restarts if it sits for 5 minutes. Is this a sensor issue or is there a setting I can change?
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Posted on Feb 22, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
jsrock516
  • 5911 Answers
SOURCE: My kenmore 500 series washer fills up part of the way then drains
You may have a condition known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple matter of drain hose placement, or lack of air gap. Before assuming you have a bad component, its always a good idea to double check your installation. If you check everything and still have problems, please let me know. I hope you find this information helpful.
Posted on Aug 22, 2009
Testimonial: "Your answer was very helpful to me. Thank you very much."
  • 1937 Answers
SOURCE: I have a kenmore 90 series 110.22912100 washer
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22912100
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 19, 2009
  • 340 Answers
SOURCE: kenmore 500 series topload washer will not spin or
if you hear the motor come on after it is filled the rubber cupler from the motor to the transmission is broken ( easy replacement ) sears sell the cupler for about 10.00 dollars
Posted on Feb 26, 2010
Kenmore washer. Water drained while sitting how to restart
you could try and unplug it for a bit to see if it will reset itself
May 10, 2014 | managemylife.com
Kenmore 500 washer agitates, but does not spin. replaced the lid switch with no change. suggestions?
Could be control unit also may be a spin sensor get parts diagram on-line to see if it has spin sensor.
Jun 12, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
821 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
