Making a lot of noise especially on spin cycle
    Problem Solver:
  • 11 Answers
Could be a bearing problem,turn the drum slowly and listen carefully you here where sound came from.Lift the drum upwards if there are a play it bearing alright.
Posted on Nov 28, 2014
jsrock516
  • 5911 Answers
SOURCE: MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Posted on Apr 29, 2007
chris0fer
  • 5 Answers
SOURCE: HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
Posted on Jun 19, 2008
SOURCE: grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Posted on Dec 29, 2008
onthejob5130
  • 640 Answers
SOURCE: Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Posted on Feb 07, 2009
  • 57 Answers
SOURCE: when entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Posted on Oct 09, 2009
My front load washer is making a scraping noise and loud noise during the spin cycle
Could be bearing failure. It's quite common in front loaders.
Feb 23, 2018 | Washing Machines
My LG front loader washer making noise in spin cycle, especially last 5 minutes, how to I fix this?
open door and see if the drum can be moved up and down or side to side a lot. if it can, then you need a new bearing most likely. this would most likely only happen on a older washer that has been used quite a bit. repairclinic.com and appliancepartspros.com both have very good videos to show how the bearing can be replaced. takes some time and work, but if everything else on the washer is good, it could be worth the trouble. good luck.
Jul 11, 2015 | LG WM Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
12 year old magic chef washing machine is making a lot of noise during spin cycles (with and without clothes in it) Kindof like a constant grinding/knocking. What should I do? Is it an expensive...
If you grab the bowl of the washer and try to spin it back and forth, does it feel loose and sloppy?
If so it is probably a bearing which might not be the easiest thing for you to change if you've never done it before. It shouldn't be very expensive, especially if you can take the machine apart and have it ready for the repair man.
Jun 07, 2011 | Magic Chef Washing Machines
Making a noise during the spin cycle
Hello, it sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves.
Thanks
May 19, 2010 | Washing Machines
WMA22- Machine has started making lot of noise.
Sounds lika main drum bearing problem
As it is only 6 months old, then you should contact service agent.as it will still be under guarantee.
Aug 02, 2008 | Hotpoint First Edition WMA22 Front Load...
Washing machine does not spin Whirlpool LLR7144
the motor coupling is probably broken. Especially if it wont wash either. Its probably just filling with water and then making noise but not actually washing. If its doing this than replace the coupling.
Jan 10, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
