Question about Maytag Dryers
Dryer stopped running what could be the problem?
5 years old could it over heat
    Habit-Forming:
  • 188 Answers
If it is completely dead, it is probably the thermal fuse. Without the model #, it's hard to say where it is or which type of fuse you have. you can check it with a meter or just jumper across it (just long enough to see if it turns on). Do not run it without the fuse as it can overheat and possibly start a fire. The blower motor blows across it to keep it cool , but if the dryer hose is clogged , the heat doesn't get out fast enough and will open the thermal fuse.
Posted on Nov 30, 2014
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
rpbuice
  • 161 Answers
SOURCE: WHIRLPOOL GAS DRYER MODEL LGQ9030PQ1 DRYER RUNS BUT NO HEAT
First, as a retired Fire Captain I must recommend turning off all running appliance before leaving the house or going to bed. I can tell you some real horror stories. Now, there are several parts that can keep the heat off or flame off and they all need to be checked with an OHM meter. It could be the ignitor, ingitor sensor, or gas solenoids. Get a service tech out to check which you need or if you have an OHM meter I can give more info on what to check.
Posted on Jan 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
  • 2287 Answers
SOURCE: 9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Posted on Nov 07, 2009
SOURCE: DEGX1 dryer will not produce any heat. 5 years
I have the same model of dryer and the same problem and no experience in fixing any appliances. I took a few screws off the top and the front, opened the dryer by rotating it forward, and found a red button (a fuse or breaker?) close to what I figured would be the heat sink. Pressed the button, it clicked, and decided to put it all back together. First load worked fine, hopefully that was all it needed. Good luck and hope this is all you have to do too.
Posted on Jun 05, 2010
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Dryer was working fine. It's between 5 and 10 years old. Suddenly stopped heating. Model #HYG3658AWW Rev 14
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Maytag HYG3658AW Gas Dryer
The dryer is 5 years old and does not seem "heat"
werrw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not inprove, you may have a defective heat coils
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
I have a 5 to 7 year old kenmore dryer it runs but does not heat. should i repair or just buy new?
Be sure to check your breakers for dryer some times only one side of the 220v will trip and the dryer will run but it wont heat. The element is the only thing that is 220V. Hope this helps. A 7 year old dryer is not that old most dryers is good for 12 to 15 years.
It would be good to pay a service call and an est. them make the choice to fix or replace
Nov 04, 2009 | Dryers
Dryer will not heating up. Only 5 years old
Two possible reasons:
1. The heating element or the temperature sensor is broken.
2. The exhaust vent is obstructed and needs to be cleaned.
Good luck.
Oct 01, 2009 | Frigidaire GLET1041A Top Load Stacked...
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
60 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
