Question about Hannspree HANNS G HU171D (Black) LCD Monitor
IM TRYING TO PLAY MY PS3 ON MY HANNSPEE HU171D MONITOR BUT THE SCREEN IS BLACK I CAN SEE THE CUMPUTER MENU BUT NOT THE GAME
I BOUGHT A DVI/HDMI CORD FOR MY GAME AND TRYED IT ON ANOTHER MONITOR AND IT WORKED FINE
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
asthanarht
  • 258 Answers
SOURCE: My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Posted on Jul 03, 2009
JomasTech
  • 66 Answers
SOURCE: I tried to hook up my ps3 to my hannspree monitor
did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
Posted on Oct 17, 2009
andik_guru
  • 146 Answers
SOURCE: No display, light goes green but on screen says no
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Posted on Mar 11, 2011
Testimonial: "This could be help to me but im sure its not the CPU"
budmrtn
  • 11361 Answers
SOURCE: I'm playing my ps3 on my hanspree monitor and the
The power supply for the backlights inverter or the inverter circuits may have gone out. I owuld inspect the caps in the power supply for any of them with domed tops, also check to see if it has any 18vdc feeding the inverter circuits.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
My monitor(HPL1950) was working good until i unplugged it to play on PS3. When i connected the monitor to my PS3 with HDMI it showed black screen. There is photo showing the screen. Help please
If your cennecting using an hdmi to dvi then you might want to check that your ps3 is only sending video and not video and sound as not all screens have a dvi port that supports sound and dvi. Also it could just be a resolution issue. Try having the resolution of your ps3 to 720 or possibly lower and see what happens. Then if all good work your way up to find what your monitor can handle.
Nov 07, 2015 | Video Game Consoles & Games
My monitor(HPL1950) was working good until i unplugged it to play on PS3. When i connected the monitor to my PS3 with HDMI it showed black screen. I cant figure out what is wrong with it
I assume you have never tried this option before. Based upon the manual for your device, it seems that you may have a compatibility issue. SOME models of your device had digital video input capability. But most operate on analog inputs only. Even the DVI jack (which ironically stands for Digital Visual Interface) on most older devices is an ANALOG input jack. Only when you get to DVI-D and DVI-DD does the input get totally digital. So what you are probably seeing is that the monitor see a signal on the DVI, but cannot comprehend it as it is looking for an analog video signal and is receiving a digital one. Here is a Wikipedia Link explaining the different DVI jacks, their capabilities and limitations.
Nov 06, 2015 | Video Game Consoles & Games
Viewsonic vx2265wm screen with the PS3
I have the same problem! I'm using the HDMI-DVI cable that came with the monitor because it lacks an actual HDMI port. DVI is the big port with the grid, right? Anyways, is there a way to put monitor Drivers on the PS3? The monitor doesn't have a menu so I can't manually resize. Also, LittleBigPlanet automatically splits like 720p whenever I play it.
Mar 21, 2010 | Video Game Consoles & Games
Welcome Screen Blinking Gateway Monitor
I would suggest that you re-install the disc. that comes with the screen.
If that doesn't work, check to see that your video card is working correctly.
May 26, 2009 | Gateway FPD1975 19" LCD Monitor
Samsung T220HD - can't access HDMI input sources
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck.
May 09, 2009 | Samsung T220HD LCD Monitor
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
what Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Hdmi to dvi
This message may occur if the signal from the video adapter exceeds the scan range of the monitor (monitor not HD enabled).
The video adapter setting on PS3 for updating the screen (the refresh rate) is incompatible with the monitor.
Mar 28, 2008 | Computers & Internet
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Hannspree HANNS G HU171D (Black) LCD Monitor Logo
37 people viewed this question
Top Hannspree Computers & Internet Experts
Tony Isted
Level 1 Expert
justwinwin
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
