Question about Tablets & eReaders
I pad keep turning on and off while charging - Tablets & eReaders
  • 30 Answers
First you must use a high powered wall charger for tablets/ipads.
the reason it keeps turning on and off is because there isn't enough battery for it to allow itself to stay on
when it is turning off there is a spinning thing that appears. plug in your charger at this time and this will stop it from trying to reboot.
if it needs the charger plugged in to try to turn on i found a neat trick that might work. you have to hold the home and sleep/reset button as soon as you see the logo screen to make it reset before it fully boots. do this over and over for about 40 times and it will eventually let you get on the tablet long enough to hold down the power button and slide to turn off the ipad.
you might be able to mix both of these fixes together for a easier and less time consuming experience but i dont know.
a dead battery may also be the cause for this and with this you will probably have to send it in to get repaired unless someone else knows how to get a spare battery and replace it.
Posted on Nov 28, 2014
Testimonial: "Cheers tried that but not work think battery no good keep seeing red battery when unplug"
    Scholar:
  • 175 Answers
A cold reset might be needed. Keep in mind that your data might be lost. If you use iTunes see if it recognizes the iPAD at all.
If it does make sure that before doing a "reset" if offers to save your data so you can restore later.
  • Carlos Krue Nov 28, 2014
    I am assuming yhat you have done what is suggested if so then you have a probelm with your iPAD. The apple people can help you at first with no charge.
  • Dani Girling Nov 29, 2014
    Have managed to turn off now and waiting to c if chargies cheers
Replacing the battery in a G Pad 7.0
Hi Amber.
A thread here has some tricks to try in the event that the charging circuit has gotten into a wonky state.
http://www.androidtablets.net/threads/lg-g-pad-battery-completely-drained-will-not-charge.70085 There also seems to be a lot of mention of the chargers going bad, and the charging port coming loose (it looks to be micro USB, so you may want to see if someone has another microUSB charger and whether charging works with that one).
This turned out to be more of a pain than anticipated finding a DIY to get inside. The best I found is here
LG Pad 8 3 Quick Teardown that gets into opening the tablet up, presumably enough that one can then swap another battery in.
Good Luck!
D
Dec 01, 2015 | Tablets & eReaders
MY ZEE PAD WILL NOT CHARGE
both of my charging ports are bad , thats your problem also, we need to find a supplier for the parts so they can be fixed..
Dec 19, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Why my tablet turns on when charging?
My ASUS Windows 8RT tablet is what I am basing this on, but it does the same thing. It's actually pretty common for the device to remain ON (standby) while charging. If you look at the battery icon, does it show anything different than usual?
May 17, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
How long will an I Pad battery last
It should last 3 to 5 years, if you keep using it until it has less than 10% power remaining, and then recharge it to 50% to 75%.
If you keep it always connected to the recharger, the battery gets "lazy", and won't hold a charge when you need to use it on battery-power.
Mar 16, 2014 | ASUS MeMO Pad HD 7
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
My asus memo hd 7 will not take a charge or turn on whatsoever..How can I fix this..?
first open your pad check the conector to volt in 4.5v maybe need a rebulding soldering do it then close your pad and work agan vote please
Nov 04, 2013 | ASUS MeMO Pad HD 7
Nextbook 7 will not turn on
my pad was charging. charger went hot pad did too then it wouldnt turn on anymore nor will it charge.
Oct 04, 2012 | Nextbook Premium 7 Capacitive Touch...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
