Question about Toys
Find out why bucket won,t go up or tilt
1996, 773
    Master:
  • 706 Answers
Check hydraulic pressure and fluid first. May have bad pump.
Posted on Nov 29, 2014
The question I asked is for 1996 773 bob cat skid steer.why bucket won,t go up or tilt
Check hydraulic pressure. Just because you changed the pump two years ago doesn't mean it isn't bad again.
Nov 28, 2014 | Cars & Trucks
Put empty bucket in,it runs for minute,then shuts off. need a switch that won't shut off. Where could I find one my zip code is 44451.
The switch may not be the problem. However, a dirty or clogged air intake filter or the humidity extraction level set to high could be.
Turn the unit OFF & unplug it.
Remove and clean the air intake filter thoroughly. Be sure the filter is completely dry, before reinstalling. Never operate the unit without the filter in place.
After the filter is dry, reinstall it, plug the unit and turn it ON. Lower the humidity extraction level to 35%. If you have an analog unit (No LED screen) set the humidity extraction knob on Maximum.
And finally, be sure that the water collection bucket is installed properly and is not vibrating loose when the unit runs. It should fit squarely into it's holder, making contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly, it should not tilt down at the bottom of the bucket.
All of the above should solve the problem and you won't need to purchase a new switch. But, in the unlikely event, that you will have to. You will need to furnish the Brand Name of the unit and the Correct Model Number. As, they are not all the same.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
I drained the water and checked the filter then i push the on button and it won't come on
This problem usually occurs when the bucket is not properly reinstalled in it's holder or the the float valve in the tank is stuck in the UP position, if your unit is so equipped.
In either case, you will have to remove the bucket. Check for the float valve and if yours has one, make sure it moves freely. Then reinstall the bucket, making sure it fits "squarely" into the holder from top to bottom and makes firm contact with the bucket safety removal switch, on the back interior wall of the holder. When the bucket is installed properly, the bottom should not tilt down at all.
Be sure to turn the unit OFF & unplug it, before removing the bucket to check the above.
I hope this helps you and thanks for choosing FixYa.
Aug 23, 2011 | Soleus 30-Pint Dehumidifier
Emtied water out of tray and machine will not strart lights are all on the top of the machine is their a reset button i did set the tray with a hose to empty by itself don't believe that would...
If the hose is still connected and it's not clogged, the water shouldn't have filled the bucket.But, let's get back to emptying the bucket and reinstalling it and the unit won't start.
Several things can cause the this. The first and most notable is the bucket is not installed properly. When that happens the bucket safety removal switch, does not make firm contact with the bucket when it's reinstalled. If the hose is still attached, temporarily remove it and reinstall the bucket so that it fits "squarely" from top to bottom into it's holder. Make sure that is makes firm contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly the bottom of the bucket should not tilt down at the bottom.
The second most notable thing, is that the humidity level in the room is the same as whet you have the unit set to extract. In this case, the unit won't turn ON, until the surrounding humidity level rises. To test this, lower the humidity extraction level to 32%. If the bucket is installed properly and the Air Intake Filter is clean, the unit should start.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 22, 2011 | Haier 65-Pint Dehumidifier
Dehumidifer FDD40J6, probably 10 years old, just stopped working. Emptied the bucket and it won't start again despite settings on dials. Electricity is working - take out bucket and light goes on.
The problem lies in the way the bucket is reinstalled or the float valve (if yours is so equipped) is stuck in the UP position.
Remove the bucket for it's holder and check for the float valve. If it is stuck in the up position, jiggle the arm to make it return to the down position. Be fore you reinstall the bucket, look at the back wall of the bucket holder. There you will see a trigger switch. It's the bucket safety removal switch. Check it to make sure it's still intact. At 10 years old it may have broken OFF. If it appears to be be intact, install the bucket "squarely" into the bucket holder from top to bottom. Being sure that it makes firm contact with the bucket safety removal switch. When installed correctly, the bottom of the bucket will not tilt down at all.
Also, check the air intake filter as it may be dirty of clogged.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | Frigidaire Dehumidifiers
It won't turn on. you will plug it in and the "full" button will flash on and off for 5 seconds then it wont show any sign of its power being on.
The last time the bucket was remove, it wasn't reinstalled properly or the float valve in the top of the bucket is stuck in the "UP" position (if yours is so equipped).
Remove the bucket and check for the float valve. If it's in the up position, jiggle the arm to make it return to the down position. Reinstall the bucket, so that it fits "squarely" from top to bottom, into it's holder. It must make firm contact with Bucket Safety Removal Switch on the back wall of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
I hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Maytag M7DH45B2A Dehumidifier
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
DE45EJ-T When you put tray in it won't turn on. If you push the lever with your finger it works without tray
That's because when you reinsert the bucket into the bucket holder, it's not making firm contact with the bucket safety removal switch. When you reinstall it, be sure that the bucket fits "squarely" into the holder from top to bottom. Once it's inserted properly, it just not tilt down on the bottom.
Jul 14, 2011 | Haier 45-Pint Dehumidifier
Ad 70 uss whirlpool dehumidifier
DEPENDING ON HOW FAR AND HOW LONG IT RAN TILTED, YOU MIGHT HAVE AN ISSUE WITH THE BUCKET SWITCH, LOCATED BEHIND THE BUCKET. SOMETIMES THERE IS A FLOAT INSIDE THE BUCKET THAT ACTIVATES THE SWITCH. IT MAY HAVE GOTTEN IN A BIND. TRY REMOVING THE BUCKET AND THEN REINSTALLING IT.
IF YOU HEAR A CLICKING NOISE ONCE EVERY FEW MINUTES, YOU MAY HAVE DAMAGED THE COMPRESSOR.
THE COMPRESSOR HAS LUBRICATING OIL IN THE BOTTOM OF IT AND REQUIRES IT BEING LEVEL TO PROPERLY PICK UP THE OIL. IF YOU TILT IT FAR ENOUGH, IT WON'T BE ABLE TO PICK UP THE OIL AND WILL DAMAGE THE INTERNAL MOVEMENT OF THE COMPRESSOR. REPLACE-MENT OF THE COMPRESSOR IS THE ONLY FIX AN TOO EXPENSIVE. BETTER TO JUNK IT AND START OVER.
Nov 23, 2007 | Whirlpool AD70USS Dehumidifier
Toys Logo
53 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
