Question about Electrolux Refrigerators
My Electrolux EW23CS65GS1 model JCD-23 the freezer makes a strange noise at the rear it sounds like it comes from inside what is it and what can I do?
  • Official Brand Answer
  • 4,342 Answers
Thanks for your post, Rob Muzich!
From the information you have provided your Electrolux refrigerator is making a strange noise at the rear. Depending on what type of noise you are hearing it could be a normal operating sound. In the manual it provides a list of sounds on page 23. I have included a digital copy of the manual for you to review. If you need any additional assistance please feel free to reconnect. -Matt
Frigidaire Manual Search Results
Posted on Dec 06, 2014
bobotfel
  • 236 Answers
SOURCE: GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Posted on Jan 09, 2008
  • 190 Answers
SOURCE: Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Posted on Apr 08, 2009
sawdust46694
  • 398 Answers
SOURCE: Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Posted on Aug 03, 2009
SOURCE: Our Smeg SR640XA side by side refrigerator is
It is the defrosting heating elements and sensors that has gone bad.
Check for glowing light at bottom of the back panel. Turn the freezer section off and contact Smeg!
Posted on Apr 03, 2010
SOURCE: Looking to download manual for Electrolux Fridge -
The manual is hosted on frigidaire's web site
Posted on Aug 17, 2010
Where is the main control board located on a EW23CS65GS1?
EW23CS65GS1 ELECTROLUX REFRIGERATOR Manual ...
www.searspartsdirect.com > Kitchen Appliance Parts > Electrolux Parts
Download Manual for Model EW23CS65GS1 ELECTROLUX REFRIGERATOR.Sears PartsDirect has parts, manuals & part diagrams for all types of repair .
Jul 26, 2015 | Washing Machines
Electrolux fridge freezer makes metalic shaking noise everytime thermostate switches off. Have checked behind front and rear panels and underneath but everything secure. Sounds like noise is coming from...
Thanks for your post, William!
I understand that you are experiencing a metal shaking noise once your thermostat switches off inside of your Electrolux refrigerator. Since there are so many metal pieces inside of your refrigerator it is hard to provide a proper diagnosis. This would require proper disassembly of your refrigerator to pinpoint what could be causing this noise. I would recommend contacting a professional technician for proper assistance. If you need assistance I would advise you to view your manufacturers website to locate a technician. Hope this helps. -Matt
Feb 28, 2015 | Electrolux Refrigerators
HIGH TEMPERTURE MESSAGE FOR FRIDGE AND FREEZER
Hi Friend, this is Z. Thank you for your post!
Did your Electrolux refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. Is your refrigerator beeping or did the alarm turn on? If so, first deactivate the alarm to your refrigerator by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best - Z
Aug 27, 2014 | Electrolux Refrigerators
Electrolux 23 cu ft refrigerator (EW23CS65GS1) Water dispenser problem. The water dispenser on the freezer door does not dispense water but the ice dispenser is working fine. I turned off my refrigerator...
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Oct 17, 2011 | KitchenAid 20.3 cu.ft. Counter-Depth...
Just became noisey , have hoovered out all the dust at the rear where motor is etc and now making a strange sound
You need to isolate the noise:
* freezer compartment
* fresh food compartment
* lower rear of refrigerator
Also, give a better description of the noise that you are hearing and how frequent.
There are several motors at work that could make noise (e.g.: freezer fan/evaporator motor, auger motor, icemaker, condenser motor and compressor).
Contact an appliance service company.
Feb 25, 2010 | Daewoo Refrigerators
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
I have a Frigidaire Upright Freezer making strange noise.
Check the condenser fan,m sounds like the bearings are failing.
Good Luck,
Gilsh
Nov 28, 2009 | Refrigerators
WHERE DO I FIND A REPLACEMENT TIMER DEFROSTER FOR FRTC03L3DS0 ... FRIGIDAIRE MANUFACTURED BY ELECTROLUX ... SMALL REFRIGERATOR WITH FREEZER COMPARTMENT SEPARATE APPX TWO YEARS OLD ... STOPPED COOLING ......
Could you recheck the model number for your refrigerator. The number you listed is for a oven. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Thanks, Sea Breeze
Mar 27, 2009 | Electrolux Refrigerators
Electrolux 23
Go to
this page at devicemanuals.com
and find your model number in the list, click on your particular model, then follow the instructions to download the manual.
Mar 17, 2008 | Freezers
Refrigerators Logo
324 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
