Question about East End Patio 10x10 Polyester Pop-Up Gazebo
How high id this canopy.
I know is 10x10 in the bottom I w want to know the High from floor to horizontal pole. The model is : 93221
Shed manuals
Contact manufacturer, they can assist you.
Sep 06, 2014 | Shelterlogic Shelter Logic 10x10 Store It...
Where do i get a replacement canopy for my 10x10 avondale gazebo?
www.ezreplacement.com/rplc-roof-bracket-avondale-gazebo.html
Lots of places. Their are also tent and awning companies that will make you up one. One on Gravois Street in St. Louis,MO. for example.
Jun 16, 2014 | Astonica Avondale 10x10 Gazebo
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
Ive got a 10x10 lawn and party gazebo made by summer rite ... do you know where to get instructions ?
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
_1430.jpgTake
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
May 30, 2011 | Camping, Backpacking & Hiking
Bought a better homes and garden 10x10 heavy duty steel frame canopy and there where no in stuctions on how to assemble. model # hc-08sm-gwm-005. where can i get this instuction manual fast?
Go to Walmart and ask for a copy of their Westhaven 10 X 10 Gazebo assembly instructions. (Same model) I tried hard to find anything on line in pdf format without success.
Kelly
May 21, 2011 | Garden
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
Aug 18, 2007 | Eddie Bauer Musical Rocking Bassinet...
East End Patio 10x10 Polyester Pop-Up Gazebo Logo
233 people viewed this question
Top East End Patio Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an East End Patio Garden Expert? Answer questions, earn points and help others
