Question about azPatio Heaters Tall Stainless Steel Commercial Patio Heater
In order to replace the thermocouple on a tall patio heater I had to disassemble the heater. The two plates with corrugated edges fell out with a round screen approx 1cm tall that was apparently sandw
First time I've worked on a heater
Why won't my patio heater light
The thermocouple has to be in contact with the flame at all times when pilot is lit, this heats up and sends mill-volts back to the safety valve to keep the gas on, if not it won't let the gas through, otherwise you need to clean the pilot or replace the thermocouple if everything else is ok..
Aug 29, 2014 | Patio Heaters
My Sunjoy L-PH007PSS-B wont stay lit.
Blocked pilot too small needs cleaning , or clean end of thermocouple ,or replace thermocouple
Nov 02, 2012 | Uniflame Table Top Outdoor Patio Heaters -...
How to change a thermocoupler for a Bluerhiono charmglow patio heater?
Hi, All patio heaters are not the same, the thermocouple can be wired up in several different ways. If you have a branded BFX750 or BFX770 patio heater it is a simple task but for a Bluerhino heater you will need to ask the supplier for instructions.
Oct 10, 2011 | Heating & Cooling
Can establish pilot flame but cannot get main flame on my jumbuck tall patio heater. everything switches off. is it the tilt switch? how do I fix this
The first thing to wear out is a thermocouple, these will cause the pilot to go out when you turn to full. To check if the tilt switch is working just short it out by joining the leads up. Found this site very useful in solutions to Patio Heater Problems.
Jul 24, 2011 | Rta International Patio Heater
I have an endless summer patio heater the pilot lights but the does not stay on when you turn the knob to start the heater. Got it on once but then the flame blew out and could not start again
You need to replace the Thermocouple. Endless Summer Patio Heaters are manufactured by Uniflame, which is owned by Blue Rhino. You can order the Thermocouple direct ly from either company. Just make sure you have your Model Number handy.
Mar 06, 2011 | Endless Summer 2009 Open Flame Patio...
I have a Charmglow patio heater. I have taken it apart and cleaned all openings where the gas comes out, but the flame still goes out after 7-8 minutes. It lights fine but will not stay lit for more than...
From what you have described, it sounds like the Thermocouple is going bad and needs to be replaced. As far as not being able to relight the pilot right away is concerned ... that's a safety feature. The control has to reset itself, before you can relight it, if the pilot goes out on it's on. As it did in your care. It usually takes about 2 - 3 minutes for the control valve to reset itself.
As far as replacing the Thermocouple is concerned, it's somewhat of a specialty item, because of it being in a tall patio heater. However, armed with the Model # of your Charmglow Patio Heater, you can probably purchase one from the manufacturer, Chamglow.
Hope this helps.
Feb 14, 2011 | Heating & Cooling
Pilot assembly parts or thermocouples
Hardware store thermocouples don't work on patio heaters. The fittings are not the same thread and they are not set up for the anti tilt safety switch. You'll need to purchase the parts from Blue Rhino.
Jan 29, 2010 | Endless Summer 233000 Open Flame Patio...
Patio Heater
The pilot light has to heat up the thermocouple. Is the thermocouple in the flame? If so, the them. could be bad. Replace
Jun 28, 2009 | Endless Summer 1501 Patio Heater
Patio Heater won't stay lit?
The first possibility is a bad regulator, easy and cheap to replace. The second possibility is a bad thermocouple, and the third possibility is a blockage in the pilot assembly. The last two problems require you to take the head apart to replace the thermocouple or clear the blockage. If you are not comfortable taking the head apart, hire someone to do it.
Jun 14, 2009 | Endless Summer gwt501a Open Flame Patio...
azPatio Heaters Tall Stainless Steel Commercial Patio Heater Logo
111 people viewed this question
Top azPatio Heaters Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an azPatio Heaters Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
