How do I adjust the picture so that the heads don't cut off?
    Problem Solver:
  • 14 Answers
The set should have aspect ratio adjustment; your set is probably set on the zoom level and must be turned down to standard or full or whatever setting nomenclature your manufacturer uses. If you don't have the owners manual you can download from the Internet.
Posted on Nov 29, 2014
Emerson TV cutting off top and bottom of display
Its picture settings should be adjusted. Now it is set to 'wide' format I assumes. If you want to get full screen, the display format should be chaged. Without a remote control, it is not possible.
May 24, 2013 | Televison & Video
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
Pioneer plasma tv picture is cutting off heads
Issue may be adjustable in the Tech menu with your remote---you need to see if you can find the service manual (with schematics and information about getting into that menu and how to adjust).
Try to GOOGLE MODEL NUMBER WITH service manual or contact Pioneer.
Mar 21, 2012 | Pioneer Elite PRO-151FD 60 in. Plasma TV
What is the wireing colors for the radio in a 92 jeep cherokee larado
All vehicles wiring is the same.
To do it right make sure you buy a wiring adapter so you don't have to cut your factory wiring plug off. Below is a wiring picture. Not all the wires in be required to hook up because some vehicles don't use them.
Blue/White (Remote Turn on): Used if sub woofer and amp system is being installed
Orange (illumination): Not every vehicle has this .. This is used to dim the radio when the head lights get turned on its own.
Blue (Power Antenna): Only used if you have one
Feb 07, 2012 | 1992 Jeep Cherokee Limited
Requesting the valve specifications and settings for both intake and exhaust on a Harley Davidson FLHS year 2000. engine 1340cc
I'm not sure what you mean by "specifications". If you are talking about angles ground on the valve and seat and their widths and such, I'll have to send you a picture but the machine shop doing the valve job on the heads should know this. If they don't, you need to find another machine shop that knows Harley-Davidson heads. As for a valve lash adjustment, there is not a setting. You have hydraulic tappets and fixed length pushrods, nothing is adjustable. The pushrods are all of different lengths and are color coded as to where they go.
Good Luck
Steve
Jul 15, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
Peoples heads are cut off on my 52 inch screen. how do I format the picture
Try to adjust it in to your remote by choosing the menu button and try look for the picture setting or picture size when adjusting it you should press the volume control in your remote up and down, it may help thank's.
Jul 09, 2011 | RCA R52WH73 Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
