Question about Mitsubishi WD-73740 73" DLP 3D 1080p Home Cinema HDTV with StreamTV In
What does 4 red and 8 yellow blinking lights mean on my 73" Misubishi tv WD 73740? I have no picture or sound.
1)I held the power button down for 10 seconds. 2)I unplugged the tv for one minute.
    Problem Solver:
  • 11 Answers
Means u need a repair guy,lol, they are usually worth their time.
Posted on Nov 29, 2014
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
  • 62 Answers
SOURCE: MY mitsubishi model LT52246 went blank on me and
means the 12 volt line has a short some place. Look towards the inverters first.
Posted on Nov 04, 2010
Testimonial: "thank youso much on what board are the inverters located I have the manuel for this tv?"
maatmartin7
  • 1229 Answers
SOURCE: The reset light is blinking
My first move would be to inspect the power supply board for bad capacitors. look for a bulged or skinned capacitor. Even if these capacitors look good, they may be failing. You will need an ESR meter to check for current. You will need an ESR meter for this. Then you will need to check the Mfs with another type of capacitor checker. These two types of capacitor checkers will be a necessity to find these failing caps. If the caps and voltages check out fine in the power supply, you will of course need to inspect and check the capacitors in the signal board. Definitely, there are bad capacitors in one or both boards. I have not repaired this particular model, but the symptoms you describe, tell where to look. Thanks for asking and show all hand of support!
Posted on May 02, 2011
Testimonial: "Thanks for taking the time to respond. I will follow your suggestions. I think it's a great palce to start. Much appreciation."
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WD-73737 73 In. HDTV-Ready TV has sound but no picture
Have a look first at the lamp to see if it is intact.
Posted on Sep 01, 2012
gopakumarg43
  • 75462 Answers
SOURCE: Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Posted on Feb 24, 2014
What does 4 red and 8 yellow blinking lights mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 24, 2015 | Mitsubishi WD-73740 73" DLP 3D 1080p Home...
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Mitsubishi 73" wd-73740 no picture or sound and red light on front
Could be power supply failure. The red light only indicates power is getting to the TV.
Jan 09, 2014 | Televison & Video
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Shuts down automatically with red light
Push device and Menu in on the front panel together and hold for 8 seconds and see if the led blinks a two digit code. As it may be the lamp or quite possibly the Power PWB capacitors if it blink a 3 4 code.
Jul 16, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-73740 73" DLP 3D 1080p Home Cinema HDTV with StreamTV In Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
