Question about Electrolux Refrigerators
Top door will not close by itself on fridge
The fridge leans to the left hand side and we have packed the left rear roller with a wooden packer which is 1cm thick. It fixes the lean and we have tried to adjust the front foot on the left side and it's extended well down and the right side is not so much, and the little adjuster which sits on the right side is well down touching the floor, and the freezer door closes by itself but the main door will not self close anymore. We have been trying to get the fridge level since we came to this house. The model number is EBM5100SA-R. It is 9 years old. Is there anyone in Auckland New Zealand that can help us. The fridge works really well and is in great condition so we don't really want to buy a new one.
    Sergeant:
  • 406 Answers
Sounds like the floor of the house.. might be your problem..Try moving the fridge out of its position and build a small flat platform in that place and level it, then place your fridge on top of it..just in case u may need a little final adjustment get those small wooden wedge shims when you get your wood..they sell them at lowes or Most lumber yards....that should take care of the leveling..good luck..good luck
Posted on Nov 28, 2014
  • 2920 Answers
SOURCE: leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Posted on Aug 27, 2008
  • 13 Answers
SOURCE: gshl5kgxls refrigerator is tilting.
well the simple solution is wood shims to level it out. Could just be your floor is not quite level. I use the cheap pine shims that you get at the hardware store.
Posted on Jun 19, 2009
  • 363 Answers
SOURCE: My new 25 cubic foot LG two door refrigerator with
The leveling jact are on the front. you would want a little lean to the back so if you close the doors and the freezer draw the don't lose their seal
Posted on Jul 24, 2009
  • 1218 Answers
SOURCE: side by side fridge door adjustment
Good day,
There is a complete warranty on the machine and cabinet for the first 12 months. The selling dealer should supply you with a free warranty service call.
There are variences allowed for such things by the manufacturer, but they should make you whole.
Contact the dealer first.
Posted on Jan 12, 2010
SOURCE: fridge side not cold-freezer great
My refrigerator's model number is TFX20JRBK WW and the freezer is cold but the fridge is not. How do I fix this?
Posted on Sep 14, 2010
Left hand door not closing easily anymore. lubricate the hinge?
It could be the fridge is tilting forward.
Up turn the two front screw beside the door to make the fridge tilt backwards, or lower down the two back screw to allow the fridge to tilt backwards.
Then the door will automatically close by the weight of the door itself!
Jan 24, 2015 | KitchenAid Refrigerators
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
2 of 3 sliding doors don`t close on tgm-69r
there is a string and a weight on the inside of each door. if you cannot find the string it may be broken. lift and remove the door from the unit, then remove two screws from both top sides of the door and the top of the door itself will come off. you can then lean the door over, the weight should slide out.
Apr 16, 2014 | Turbo Air Refrigerators
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
Freezer seal
Good day,
The first step is to make sure the machine is leveled properly.
It should not be allowed to lean to the left. As well, the adjusters should be set, so there is a slight tilt to the rear, so the doors have a tendency to close on their own.
The freezer gasket should be cleaned, as well as the frame it makes contact with.
The reason this happens is a lot of air is pushed into the machine when the main door is closed. There are 2 openings between the main compartment and the freezer, so the air is forced into the freezer compartment, wanting to push it open.
If the gasket on the freezer fits well, then the problem, is the gasket's magnets have become weak.
The repair is replacing the gasket. However, many people find ways to use the machine by adjusting their habits to ensure the door closes. One example is to keep a hand on the freezer door when closing the main door, or, closing the fridge door slower.
In any case it's your decision as to what you want to do.
Feb 09, 2010 | Kenmore Refrigerators
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Refrigerator does not level tilts to rear extremly unit rolls foward when opening doors
there should be two set screws at the top of the rollers . to adjust if I am correct you turn these screws to the left to raise the front. These screws are above the rollers as I said however, if you use a phone book to hold up the front of the fridge it will take pressure off the rollers making their adjustments easier
Good Luck
Dave
Aug 28, 2009 | Jenn-Air JCD2389G Side by Side...
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Refrigerators Logo
61 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
