Question about Samsung Televison & Video
MY SAMSUNG TV IS HAVING TROUBLE TURNING ON IT HAS NO PICTURE SHOWING AND I ALREADY CHANGED THE POWER SUPPLY HOW CAN I FIX THIS?
I ALREADY CHANGED THE POWER SUPPLY THE MODEL IS LN-S4041D
    Problem Solver:
  • 11 Answers
You can try the main pcb,only part left to change
Posted on Nov 29, 2014
jerryg50
  • 1689 Answers
SOURCE: Picture Size problem with Samsung Flat panel LN-T3253H
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Posted on Apr 12, 2008
  • 7 Answers
SOURCE: tv wont turn on
Mine was doing that then it quit even turning on too so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
ginko
  • 19396 Answers
SOURCE: sound no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 3 Answers
SOURCE: my samsung 40
This tv has issues with 4 capacitors. These caps can be replaced for about $10. They are located at the top right corner of the power supply. They will read 10v,1000uF. I had the same problem, then I replaced them wit 16v,1000uF capacitors. And presto tv!
Posted on Jul 19, 2009
budmrtn
  • 11361 Answers
SOURCE: Slow to show picture after turning tv on. Takes
Look for bad caps (leaking/bulging top) in the power supply module. Make sure to replace them with good quality caps such as PANASONIC FM/FC series.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 01, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Why do my Samsung LED TV turn on with correct sound but don't have picture. The screen stays black. I've already changed my power supply card by a new one?
If TV menu comes on try another source via hdmi could be a source issue with hdcp or copy guard issues. Sound isn't copy guarded but picture is.
Jun 04, 2014 | Samsung 5 Series UE32F5000 32" LED TV...
Samsung tv keeps switching off
Samsung has had quite a bit of trouble with their televisions turning off. For some this is a problem with the power supply but if your power light is on, that is unlikely. If you unplug your television, will it turn on again? First thing I wold do is to check for a firmware update and download it to a USB drive. Unplug the cable and using the menu on the TV, update the firmware. After updating, hold he exit key down for 30 seconds and reset the TV. If that does not work, you may need your power supply changed.
Jul 10, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 11, 2011 | Samsung PS42B430 42 in. Plasma TV
Hi, my Samsung LCD TV has been having issues for awhile when it's turning on, it would sometimes take about 5 to 10 minutes to turn on. Its turning on time has consistanly increased and now will not turn...
U have basic electronic skills?Have all the tools?Take the tv aparts,the board where the power a/c plug into it.That the power supply board,check for these parts call capacitors,it dying about to fail,that why it take power longtime to come on.These capacitors parts on the power supply board are alway bulges up on it tops or puffing up on it tops.This capacitors are dying and leaking.Replaced these capacitors,will solved ur delaying power up tv problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 02, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Red dots across the screen
Please check the power supply board, if there is any Pup-Up electrolytic capacitors, please replace them.
May 25, 2017 | Samsung LN-T4665F 46 in. LCD Television
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Polarid tv-dvd combo power trouble
TROUBLE WITH REMOT CONTROL. I CANNOT PROGRAM MY DIRECT DISH
Jan 02, 2008 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
