Question about Crafts & Hobbies
My vision line 700e Hudson will not respond to my remote? The sounds come on. All my other legacy engines respond just fine.
I have reprogramed it. I have cleaned the track and wheels. I have powered it up and down several times.
3 Suggested Answers
SOURCE: can't find button under dash to reset/reprogram keyless entry
check this out - its not like the previous link - the button actually floats around with the wiring.
http://www.rs25.com/forums/showthread.php?s=8876327367f08262d9b387a75d9b5919&t=41265&page=2
Posted on Dec 28, 2008
  • 62 Answers
SOURCE: 1995 subaru legacy L wagon. drivers side master
You just did. Its the master switch. Buy a switch from a large parts store, use a flat tip screwdriver to remove switch then install new switch. This should take you about 20 mins. Super Easy
Posted on Jan 05, 2010
Automatic garage door not responding to any transmitters
Sounds like you need to reprogram all the remotes. Instructions should be with the new unit and even on the back of the unit up top .I just reprogrammed all of mine. When I installed my wall unit the others quit as well so I reprogrammed them. all.
Jan 01, 2016 | Building Materials
Vehicle will respond but not lock/unlock
reprogram the remotes by following the vehicles owner Manuel
if you can't get them reprogrammed then its dealer time.
Mar 11, 2014 | 5301 LE 2 Way Car Remote Starter System
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
Tv does not respond to the remote with sound
The most common solution to your problem is to install new batteries to the remote. Also sometimes the batteries are loose, fix this by putting a card board wedge between the batteries and the battery cover.If this does not work try reprograming your remote.
Feb 20, 2010 | Sony Audio Players & Recorders
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
LG 700E monitor gives a blurr vision
open unit, adjust focus pot on flyback, may have 2 focus pots.
do both until satisfied.
If the problem varies with temperature (on time), then you may have a failing flyback.
Oct 02, 2008 | LG Studioworks 700S 17" CRT Monitor
ViewSonic RC00070P remote issue
Hi jdsoldan,
Where did you buy the new one? I have the same problem.
Thanks,
Aug 26, 2008 | Televison & Video
TV won't respond to ANY remote control
unplug the tv, wait 1 minute so it resets to factory settings then reprogram the remote
Aug 21, 2007 | RCA F36450 36" TV
Crafts & Hobbies Logo
44 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
