How do I clean the inside of the lens on my wonderwall 1625073 projector
    Sergeant:
  • 320 Answers
It is recommended only cleaning the outside of most projector lenses. However if obstructions have worked their way into the case and will not leave the lens, you may be able to remove the bulb (carefully, following the manuals instructions for bulb replacement)
And gently spray inside towards the lens where the bulb was. However, keep in mind the display itself sits between the bulb and the lenses,
Some projectors have air fins along the sides of the lens, some air in these fins can also loosen debris away from the lens.
Ensure the front of the lens is not dirty and that the focus has been properly adjusted before cleaning the back of the lens.
Posted on Dec 02, 2014
  • 27 Answers
SOURCE: vpl cs5 dusty lens from the inside
not too difficult to do.
requires cover off and minor strip down.
if unsure consult a tech.
Posted on Feb 26, 2008
SOURCE: Wonderwall projector has black spot in middle of screen
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Posted on Nov 15, 2009
projdoc
  • 2236 Answers
SOURCE: how can i get inside the projector.i need to clean
remove the lens rings using a flathead screwdriver and carefully pop them off. remove the 4 brass screws and the 4 silver screws from the bottom, and the 2 silver screws from the back. lift up the back panel from the bottom just a little. using a flathead screwdriver, pop open the 3 clips through the top vent of the rear panel. remove the rear panel. unplug the wire harness on the left and the small one on the right. lift up the top panel from the back a little bit and the front panel from the bottom. they will come off as one piece. be sure to blow out all of the dust with canned air. it's dry and there won't be any foreign particles in it. when you put everything back together, release the clip that attach the front to the top. put the top back on first, plug in the wire harnesses, then put on the front and rear panels. replace the screws. done.
Posted on Dec 08, 2009
projdoc
  • 2236 Answers
SOURCE: discovery projector no sound
go into the menu and select the internal speakers.
Posted on Dec 28, 2009
SOURCE: How do I remove the
You can get the service manual on the link below
http://www.avsolutions.ca/sites/avsolutions/files/catalog/8645.pdf
Posted on Jan 06, 2011
I am borrowing projector 1625073 from a friend but i dont know how to connect it to my labtop please help
Please start with the make and model of both the projector and your laptop. Without that, we have no idea what cable and/or adapter you might need. 1625073 doesn't mean anything to me, it's really of no help.
Apr 29, 2016 | Office Equipment & Supplies
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
When i plug it in makes noise like it will power up but when i press the power button nothing happens
Review: Discovery Wonderwall Multimedia Projector ...
? 15:01
https://www.youtube.com/watch?v=GYrFFrbWm5U
Dec 3, 2010 - Uploaded by georgef551
This is a review of the Discovery Wonderwall MultimediaProjector, ... twist the lens to focus the image, up to at least 120" (can go farther), but you'll ... RGB elements, which stands outlike a sore thumb when video gets .... The bulb will just make the display more true, and possibly, ... sound compared to 3m?Missing: power ‎power
Discovery Expedition Wonderwall Entertainment Projector
www.amazon.com/...Wonderwall-Entertainment-Proje...
Amazon.com, Inc.
Rating: 2.7 - ‎60 reviews
Amazon.com: Discovery Expedition Wonderwall Entertainment Projector: ... color contrast, volume control, distinct power on/off button, LED indicator light .... A lot of reviews complained about the fan noise and speaker level, but I thought .... I got it for Christmas to play video games on and you can't even make out the words.
Amazon.com: Discovery Expedition Entertainment Projector ...
www.amazon.com/...Entertainment-Projector/.../B002...
Amazon.com, Inc.
Rating: 2.5 - ‎267 reviews
Jan 05, 2016 | Discovery Channel Discovery Expedition...
How do I access the lens to clean it from the inside on my wonderwall projector 1625073
Although it may look dirty, cleaning is not recommended. If it's so dirty that it impacts the picture, take it to a qualified service center and have it professionally done.
Nov 28, 2014 | Office Equipment & Supplies
No picture comes out when i plug in my wonderwall projector?
Could be no power where you plugged in or a bad light, switch or fuse if it has one. Check the wiring for burned connections.
Oct 08, 2014 | Discovery Channel Discovery Expedition...
Why won't the Light won't turn on wonderwall 1625073
Many times on LCDs the backlight will burn out. Sometimes these can be replaced depending on design of the screen. Other issues could be the circuit that controls the backlight loses a component and causes the same issue.
Aug 20, 2014 | Televison & Video
Is there any way that I can connect my new WONDERWALL projector to my laptop computer
The wonderwall does NOT have the proper inputs for use with a computer for good reason.
A wonderwall projector is NOT a projector that is good enough to be used for movies or games and it would be embarrassing to make a presentation on one. It has WAY less resolution than even old fashioned standard definition TV. Standard def Tv is 720x 480 pixels at 30 cycles. A wonderwall is 480x 240 pixels which is appx. the resolution of a screen on your phone. That's 345,600 for STANDARD def versus only 115,200 pixels for a wonderwall. When you blow that up to 3 feet wide, it'll look pretty mediocre. We have one just like it and we use it to project VHS onto our garage during Halloween and Christmas.
It IS perfect for fun and might be ok to watch old VHS tapes but watching a dvd on one is horrible.
Your 1440 has VGA outputs. A wonderwall has AV (red, white yellow) inputs. You can buy a vga to AV adapter for less than 10 dollars almost anywhere. You don't even need to go to a specialty electronics store.
Dec 17, 2012 | Discovery Channel Discovery Expedition...
How to connect wonderwall projector to computer?
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 23, 2012 | Discovery Channel Discovery Expedition...
There is dust inside the lens. how do I clean the dust from inside the lens?
Your projector needs little maintenance. The only thing you need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp. Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
Nov 27, 2010 | BenQ MP623 DLP Projector
Sound from Wonderwall Project
make sure the ground (earth) is good. make sure there are no obstructions in the fan (paper, labels, packing peanuts, styrofoam, etc.). you may need to replace the fan itself.
Dec 26, 2009 | InFocus LP70+ Multimedia Projector
311 people viewed this question
k24674
