Question about KitchenAid Kitchen Ranges
Replace the ballast on a KitchenAid range hood model kwvu265yba
Replaced lamp and starter still lamp does not turn on.
  • 50 Answers
SOURCE: lamp won't turn on
Is this a Hitachi?
Posted on Feb 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: Where Is the Ballast.
The ballast is on the other side of the lamp compartment. the lamp plugs into the two short leads that are attached to the ballast. Its a small circuit board.
Posted on Jun 13, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: I need a PWB POWER SUPPLY for a WD-62525 MITSUBISHI DLPTV
1-800-553-7278, this is mitsubishi parts dept
Posted on Dec 06, 2008
SOURCE: Need to buy a lamp & Ballast
http://electrified.com/Catalog/Items/?CampaignID=Froogle&ItemID=35508
Posted on Dec 20, 2008
saidneurot
  • 128 Answers
SOURCE: REPLACED LAMP AND LAMP BALLAST IN SAMSUNG HLS6187 - NOT WORKING
the problem will be the board
Posted on Dec 24, 2009
I have Sunquest Pro 16s tanning bed that I have just replaced all of the bulbs. One will still not light. Can anyone help?
There are no starters on the 16s. Did the position work before you replaced the bulb? If not and it still doesnt work with the new lamp, it is either a lampholder or ballast. If it worked before and doesnt now, it is either not in correctly or its a bad lamp, you can verify by swithching with another lamp
Jun 03, 2016 | Health & Beauty
My ford 2001 v10 f250 does not crank start or click what wrong change starter and solenoids
Might be bad starter relay, or bad ignition switch. Check for voltage to starter when key in start position, or turn on headlamps and try to start. If lamps dim, bad battery connections, bad ground, bad replaced starer. If lamps do not dim, starter position on switch may be bad. You could try using jumper from battery to start post on solenoid to see if it cranks. If it does, you have either a bad ignition switch, start relay, or wiring problem.
Dec 18, 2014 | Ford Cars & Trucks
Why won't my 2012 Toyota Sienna LE Won't Start ? What is the problem with the car
Try to knock in the starter with long iron in the same time another person start the engine if it start renew it if not check the 12 volt on the starter unplug the slim wire connector from the starter and connect
a 12volt tester lamp to the female connector turn the ignition to the start position if the tester light the problem is the starter if not
the problem is in starter relay or ignition switch
Jul 16, 2014 | 2012 Toyota Sienna Base 7-Passenger...
Just purchased bed. 5 lamps not lighting and 1 on canopy blew immediately after turning on. replaced lamps, replaced starters and holders. still have the same issue and have tried 2 more lamps in the one...
Have a trained technician to check the voltage going to the bed. If all bulbs / ballasts have same problem, this may be the problem. You may need a Buck/Booster.
Jul 04, 2011 | Wolff Sunvision Pro 24S Tanning Bed
Just had starter replaced worked for 2 days and now when I try to start the car, nothing from the starter. Tested wires to starter, there is only 12volts but no ground when key is turned in ignition, is my...
The ground to the starter is the body or the chassis of the engine. So if there is 12 volt to the starter then you must take the current test of the voltage. Use a test lamp to check if not the solenoid or the starter brushes are bad.
Mar 19, 2011 | 1997 Mitsubishi Diamante
I have a lg dlp projection tv that while i was watching it it just popped and shut off. thought it was a bulb so i change that but nothing. what is happening is when i turn the power button on the yellow...
Lets statrt with the obvious, did the lamp that you replaced showed any type of damage(blown, broken) and when you put in the replacement lamp did you also replaced the lamp cover? or at least remembered to activate the door switch? these tvs have a starter board if everything checks out see if you get any type of activation sound whent you turn the power on, kind of a click sound and another thing to look for is the ventilation fan, is it activating when you push the power button?
Sep 05, 2009 | LG RU-44SZ63D Television
91 olds cutlass supreame 3.1 when runing turn ignition off.try to start immeaditely after.completely dead,sometimes after waiting appx.15 minuets it may start.replaced battery&starter no change.
Greeting's Bigcat.. Did you check all the fuses in the car as a first start..? If not you may want to as it could be one that controls the system . Ok... if you did you may want to see if you are getting power to the starter with a test lamp put the clamp on a piece of metal and hold the point to the starter cable ..have another person try to start the car , if you get power to the starter the probe should light up if and it would be the starter ...if the test lamp did not light up then it is a electrical issue in the ignition system and you will have to check all the wires in the starting circuit.
Mar 29, 2009 | 1991 Oldsmobile Cutlass Supreme
Replaced starter, now turns over, but no start
make sure all wires were reconected to starter
Aug 18, 2008 | 1996 Chevrolet Cavalier
I just replaced my lamp
which light is flashing?? there are two green lights. the timer light and the lamp light.if the lamp light is flashing you have a bad lamp or a bad HV-Starter.Could be a bad DMD-Board as well
Jan 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Open Questions:
Kitchen Ranges Logo
83 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
