Question about Singer Sewing Machines
How do i fix thread tension on Singer 191D300A industrial sewing machine?
Thread is bunching. Already cleaned tension and bobbin areas of dust
    Sergeant:
  • Singer Expert
  • 449 Answers
Make sure the bobbin is spinning in the correct direction before you try to sew. Where is the thread collecting? Under the needle plate?
A few other things can be wrong. I will need more information.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Posted on Nov 30, 2014
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Posted on Apr 19, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
Bobbin thread bunching up on bottom side od material while sewinginto a mess, while top thread fine. HOW DO I fix this, please.
Hi, this is a lack of lower tension. Check to make sure your bobbin is seated correctly and that you have used the correct thread path. Check the tension by drawing some thread from the bobbin with your hand, if it reels off too easily, the tension hook for the bobbin is too loose, tighten it down a tiny bit with a small screw driver and try again. If the bobbin tension is normal, than the problem may be your upper tension, if it is too tight it can cause your bobbin to snarl. If a tension adjustment does not fix the problem, you may need to seek a specialist.
Oct 06, 2015 | Singer Sewing Machines
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
My bottom stitches are bunching up every 10-15 stitches. I cleaned my bobbin area.
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Singer 7422
My Singer 5050C wants to bunch the thread underneath
Make sure to thread machine with the presser foot raised. Then make sure thread gets in between the tension discs and that you have the machine threaded correctly with the thread going up and into the take-up arm. tension should be set at 4-5.
Oct 18, 2009 | Singer 5050 Mechanical Sewing Machine
Bobbin problems
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Aug 24, 2008 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
67 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
