Question about Depo Auto Parts 2004 Honda CRV New A/C Condenser Cooling Fan Assembly-Shroud Blade Motor
Is there anyway to by pass the air conditiuning system ?
REPLACING THE PULLY
    Genius:
  • 1,066 Answers
Replacing the pulley with a dummy is the only sure fix, if your compressor bearings have gone bad, and you arent going to replace the compressor
Posted on Jan 03, 2015
My problem is a no heat issue with my 97 ford taurus wagon engine is a 3.0 single ohd i have just replaced my water pump T-stat and idler pully i have flow through the system and still no heat the blend...
you will have to check the heater hoses to see if they are both at the same temperature by touching them.if one is warmer/hotter than the other and there is no air in the system then the heater core is plugged and needs replacing.
Sep 15, 2011 | Ford Taurus Cars & Trucks
How to replace power steering pully bearing
you don't, you have to replace the power steering pump......sorry but replacing the pump is easier the replacing the bearing anyway. in order to replace the bearing the pump has to be disassembled and that takes some special tools and equipment all you need is basic hand tools to replace the pump.
Feb 21, 2011 | 1998 Nissan Frontier
I clean the filter almost everyday because it freezes and no cold air comes out.frigidaire faa068p7a is this normal?
The evaporator maybe dirty. You can flush it water. There is also a spray available at A/C supply for cleaning evaporators. Anyway the evaporator is the radiator looking thing at the front behind the air filter. Air passes through it to provide cooling air. It gets very cold and if the air cannot pass through it will freeze.
Jul 22, 2010 | Frigidaire FAA068P7A Air Conditioner
1996 ford taraus 3.0 with air air froze up. CAN
Many auto parts sell an idler pulley to by pass the a/c compr. will have to get this part, putting a smaller belt will not work cause it will rub on some thing else, also compr will have to be remove for this part to bolt on in it's place.
Jul 14, 2010 | 1996 Ford Taurus
When i spin the pully on the air conditioning compressor it is not smooth,it sounds like the bearings are dry.is there anyway to fix this.thank you for any help you can pass my way.
I believe you are turning the clutch on the compressor without it engaged. The clutch has what are like brake shoes inside the pulley and they would probably give you that dry sound when they are lightly dragging on the inside of the pulley
May 04, 2010 | 1996 Nissan 200SX
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
The belt that runs the water pump on 1995 Auora
Looks like the belt got hot??? You mean there are shreds of belt material all over the place? If so you have a locked pully somepalce. Replacing the belt is easy, find the diagram of the belt system under your hood. Find the pully that is the tensionor pully. Fine the correct wrench, remove tension, slip of belt from one pulley. remove belt completely, then, since you have shredded belt material, spin each pulley and see which one isn't turning easily. All the pullies will spin easily execpt for the crank. If you have one that's not, well, that one is shot. Needs to be replaced. And if may not just be the pully, might be the accesory which the pulley sits on. Example, water pump, altenator, etc....
Nov 23, 2008 | 1995 Oldsmobile Aurora
Air conditioner pulley
yes go to autozone .com get a/c by pass pully $39.99
Aug 03, 2008 | 1994 Pontiac Bonneville
Depo Auto Parts 2004 Honda CRV New A/C Condenser Cooling Fan Assembly-Shroud Blade Motor Logo
82 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Kar Volk
Tom Chichester
David Ellis Rhea
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
