Question about Staples SPL826X (CrossCut) Shredder
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
I have tried to get it to shredd by turning it off and turning it back on, but no luck
  • 53 Answers
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
Posted on Nov 28, 2014
I have royal px110mx and it won't shredd my papers. When turned on and put a paper, it will be making noise and not shredd the paper. Can someone bail me out.
Your Royal shredder probably hasn't been cleaned since the day it was first used. Take a look at the shredding mechanism and you will find bits and pieces of everything. A thorough cleaning should get your shredder working again. Be prepared to spend considerable time on maintenance.
Jul 20, 2016 | Royal Office Equipment & Supplies
My shredder will not shredd paper
1. There is usually a small metal piece in the basket portion that has to hit the shredder when in place. If it gets bent, it won't line up and wont work. You can easily bend it to fit if that's the problem.
2. In general most people (like me) get all excited the first day of a new shredder. It will automatically STOP when it over heats. Don't worry, just wait until it cools itself long enough, turn it back on and it works again.
3. Aluminum in a shredder??? Never heard of that. sorry.
Sep 18, 2014 | Shredder Secure Shred Shredder
How do I fix my blades on my shredder?
Try running a layer of aluminum foil between two sheets of paper. See if it shredds, If it does, do it a couple of times, then use shredder oil. It might help to both sharpen the blades, and to keep them sharp longer. It works on cutting blades for scrapbooking cutters and scissors...
Aug 18, 2014 | Shredder Secure Shred Shredder
Lockout key replacement for paper shredder model# SPL-TXC122A
I am not sure what you mean by a LOCK OUT KEY but perhaps this link to the manufactures site might help.
www.fellowes.com/us/en/support/Pages/faqs.aspx Fellowes Support FAQs
Jul 13, 2014 | Staples SPL826X (CrossCut) Shredder
The motor will hum when you put the paper to the blades but it will not shredd because the blades do not turn.
Blades need to be cleaned and oiled Unplug and check to make sure there are no staples or something caught in the gear edge in the corners You should be able to turn it by hand If not the gears inside probably slipped out of place or got busted from somebody trying to shred too much at once
Apr 24, 2014 | Royal 160MX Shredder
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Four sheets were being shredded and within them there was a credit card. The whole thing jammed. I dug out all of the paper I could but the wheels won't turn. The machine tries to go but no movement from...
While this is not user serviceable, dismantling a shredder is not difficult ... usually.
First you need a sturdy flat working surface about 3' x 5', a large Philips screwdriver and .... a vacuum.
Make sure to UNPLUG THE SHREDDER.
I guess you can just lift the top off the basket, turn it upside down and place it on the working surface.
At this point you may want to run the vacuum on the underside.
You should see at least 6 screws holding the bottom cover.
Once you remove them, the guttyworks should be in plain view.
Another run of the vacuum and you're ready to "operate".
It's not a pretty job because of the gear lubricant, but if you can, turn the motor shaft itself.
It's a slow process but the blades will soon let go of whatever is left of your credit card.
Once it is all out, replace the cover and place the shredder securely on the basket and plug it in.
Good luck.
Feel free to contact me if you wish.
Feb 15, 2011 | Staples SPL826X (CrossCut) Shredder
My shredder work on reverse but not on auto mode the ready led is on but when i try to shredd,.. nothing happends . inside everithing is clean and i see no brken parts or wires detach
Try cleaning the "eyes" in the middle of the slot where you put the paper in, they can get dusty and not detect the paper being put in.
Sep 18, 2010 | Royal VF1000MX Shredder
Staples SPL826X (CrossCut) Shredder Logo
473 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
