Question about 4103LX 4Button Remote Start System with Keyless Entry
So i had a avital 4103 installed on a 98 nissan pathfinder and all was working perfectly, now however the 2nd status output (which i have connected to my rear defroster) will not activate when pressin
So i had a avital 4103 installed on a 98 nissan pathfinder and all was working perfectly, now however the 2nd status output (which i have connected to my rear defroster) will not activate when pressing unlock, lock and start button at the same time, which would normally cause the lights to flash 4 times and make the rear defroster activate 10 seconds after the car has been remote started. i have checked that it is programed to the right option (option 3 -pulsed). I have checked the wiring to the back of the defroster switch also. im guessing this must just be a malfunction and you will not be able to help me, just thought id ask anyway.
5 Suggested Answers
  • 34 Answers
SOURCE: im about to install a
the one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
  • 1833 Answers
SOURCE: After starting vehicle with remote
According to your problem you can first change your remote battery to if it is not malfunctioned for battery. Before start the vehicle press lock key for 1 second to lock the door from remote. If the door locks are connected then horn will honk and the parking light will flash once. If the system is armed then status Led will flash once per second. After check it you can start your vehicle. But don't remote start your vehicle when the key is in ignition. It may help you to solve your problem.
To know more you can follow the manual.
Posted on Mar 16, 2011
prashant9879
  • 3 Answers
SOURCE: Avital 4103 remote start: battery disconnected, now starts but kills within a few seconds
pliz Stop SMS My no 9726494044
Posted on Feb 07, 2014
Transmission
Often this kind of problem it is caused from faulty throttle position sensor, you find out by connecting a code reader to your car computer.
Aug 16, 2008 | 1998 Nissan Pathfinder
I have an avital 4103 in my 2004 silverado. It won't unlock the doors and it starts but immediately quits.
There is a bypass module that communicates with the truck. It's in addition to the 4103 system. It's lost its programming or is disconnected. Sometimes you can unplug the module, turn the key on, plug module back in, turn key off, then on and start. All should be working fine again.
Jan 14, 2014 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
My avital 4103 does not unlock the passenger door when unlocking OR set the alarm when locking - should it?
Its not the avital piece that's the problem, it's your INSTALLER that is/was the problem....haha, got somethin wired wrong!! It only does what you install it to do! :)
Dec 11, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
4103LX 4Button Remote Start System with Keyless Entry Logo
55 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
