Question about WELLY 1999 Jaguar SType Red 118 Diecast Model Car
Why will my car not start after changing the air condition refrigerator ?
Checked fuses and changed battery
    New Friend:
You have disconnected a wire that told the brain not to start the car. disconnect your battery for a few minutes it will reset the brain.
Posted on Nov 28, 2014
Changed my battery and now my radio, a/c and heat won't work. Instrument panel shows the battery light, ESC, and brake light???
Did you take off the cables prior charging battery
If not you would have blown a fuse locate the fuse and check all fuses
Feb 14, 2015 | 2008 Hyundai Sonata
2006 zephyr. Brake lights don't work and car will not go into gear. We checked the battery and it was falling apart. We changed battery. We changed fuse 21 and the fuse immediately blew. Any o
For a fuse to blow there is a dead short in the circuit after that fuse. Check for correct bulbs in use, damaged wiring /burnt wires. Reset the CPU after the battery change by the use of a scanner.
Oct 04, 2014 | Cars & Trucks
Losing power in 2001 taurus
Pull all of your fuses, disconnect the Positive lead from the Battery and use a Multi Meter between the cable and battery post. with the ignition on off. Check the voltage, now replace the fuses one at a time and watch for a change in voltage. The fuse that causes a change will be the one that goes to what is draining your battery.
Jan 04, 2014 | 2001 Ford Taurus
2005 vw Jetta no power to the radio
changing a battery should not blow a fuse if changed correctly ie ign off and all electricks switched off ,,,, disconnecting earth first and connecting it last when putting in new battery ,,,,, maby its just a security code you need for it as this will happen in some cases when you disconnect the battery ,,,,, if it is a fuse i do not know the fuse number but it will be a low ampage fuse ,, usually a 5 amp fuse ,,, most cars have a few fuse boxes now so look for two fuse boxes at least ,,,
Dec 06, 2013 | 2006 Volkswagen Jetta
91 Acura legend won't turn over. Changed the starter relay and checked the starter, it's good. Now what do I do?
Power flows from Fuse 35 50A to IGN switch. Start by checking that fuse. From IGN switch to starter on black/white wire. Check for battery voltage on that wire at starter. If no voltage, check for voltage on black/white wire at IGN when turned to START. If no voltage, check for good power coming into the IGN switch on the the white wire from Fuse 35
Feb 04, 2018 | Cars & Trucks
In the fuse block there is a fuse labeled battery that keeps blowing what could be wrong
Check if fuse is okay with the regulator disconnected. If it is okay there is a short in the regulator. If not there is a short between the wiring between the regulator and the main fuse.
Oct 03, 2012 | 2006 Harley Davidson FLHR Road king
Ignition Fuse blowing Honda Sabre VT1100
YOU ANSWERED YOU"RE OWN QUESTION,SWITCH,AND RELAY,LOL
Apr 05, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
WELLY 1999 Jaguar SType Red 118 Diecast Model Car Logo
408 people viewed this question
Top WELLY Toys Experts
xkikbxr
Todd Arndt
Todd Arndt
RSole
Are you a WELLY Toy Expert? Answer questions, earn points and help others
