Installed new control panel on mfw900sq1 and will not turn on
    Genius:
  • 1,554 Answers
Im getting a blank here too
Posted on Nov 28, 2014
I installed a new pc board part number WE4M536. Now when I turn on the dryer, all the LED's just blink on & off. Do I need to program the new board? If so, how do I program it?
Yes it sound like it needs programed to your model number. Should have been instructions in the part box. There may be instructions inside the control panel. GE usually puts a sheet of paper with service info inside most dryer control panels. It usually consists of pressing 2 buttons at the same time to get in service mode and then turning the big knob to set it.
Jun 06, 2015 | Dryers
Samsung Range control panel won't turn on.
Check the voltage at the ac cord. Make sure you have 240 there. Sounds like your missing one leg there
Mar 24, 2014 | Samsung NE595R0ABBB 5.9 cu. ft. Large...
I just replaced front control panel but when I turn on oven to bake it flashes an F5 error code. What is the problem. Could the new control panel be faulty?
This is probably because of a poor connection on the relay board, or a bad sensor connection. If the f5 error code was not the original problem (and just appeared since you installed the new panel) you probably did not connect the harnesses exactly right.
Mar 25, 2011 | Jenn-Air SCE30600 Slide-In Electric...
The screen says F7 and an alarm keeps beeping
One of the most common problems with GE electric built in ovens is the error code "F7′ shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the "search" button and in the new window type the word "control panel" in the "search by keyword" box and click the "search" button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Oct 25, 2010 | Thermador SC302T Electric Double Oven
Have HP dv6110 TX2 will not turn on no external audio
GO INTO CONTROL PANEL, GO TO DEVICE MANAGER, CHECK THE MEDIA CENTER, SOUND, VIDEO AND GAMESS,
OR
CONTROL PANEL OPEN SOUND FOLDER, SEE IF THE DEVICE YOU HAVE IS LISTED IN THE SETTING AND IF NOT THAN YOU WILL HAVE TO GO TO CONTROL PANEL TO ADDING NEW HARDWARE AND TRY TO INSTALL AS NEW DEVICE.
IF YOU ARE IN SOUND IN THE CONTROL PANEL, GO TO THE SOUND TAB AND OPEN THE FOLDER, THAN GO TO SOUND SCHEME , OPEN THE PULL DOWN WINDOWS AND SLECT THE NO SOUND AND FOLLOW THE INSTRUCTIONS.
ROD
May 09, 2009 | HP Pavilion dv6000z Notebook
I have a new ACER netbook and it won't let me install windows update
Is windows update turned on ? Check Administrative options services or use control panel to check settings. It may be a windows copy - if so it will not allow updates.
Apr 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
Aprilaire 600 humidifier solonoid valve chattering in sync with d10 led
I fixed my problem by ordering a new control unit (model 56) from IAQSOURCE. Installing the control unit took a few mintues, and once the new control module was installed, I've had no more problems. The URL is as follows: http://www.iaqsource.com
Oct 12, 2007 | Aprilaire 600 Humidifier
Power up Issues
I am suffering from the same problem and I called Xerox. The problem is your control panel and this is a known defect for this printer. My replacement os on its way. It appears that if you take off the control panel, you can find a bad soldier joint.
Aug 24, 2007 | Xerox Phaser 8550/DT Thermal Printer
32 people viewed this question
k24674
jasbo
jasbo
