Question about Video Cameras
How do I get the little adapter out that is stuck in there. can't get it out Help!
I tried a toothpick,its relly stuck, maybe I did not put it in right. They are to dam small!
    Genius:
  • 1,554 Answers
You kilt it.
find a helpful nerd .
pull it out can damage it or whats left .
a little sugery is now needed .
or a tiny tiny squirt of wd40 but that can leach around the screen.
anything i tell you to do will likely lead into its disposal unless you get tech help.you have to be fearless to work on some things
we would need a lot more info on this to do this exactly.
Posted on Nov 28, 2014
I need pa3758u-1mpc wireless driver.. any help?
Maybe you don't. In control panel go to Device Manager. Click on the little arrow next to Network adapters. Right click the adapter and uninstall it. (don't delete drivers if asked) Then re start your computer & see if that repairs the bad driver.
If that doesn't fix it,(YOU MUST USE SOME WAY TO GET ON THE INTERNET) (plug in to your router or use a portable usb wifi adapter) repeat the same steps & rt click the adapter & Update driver & select Search automatically (not find on this computer) . It goes on line to Microsoft & it searches it's driver base & finds the proper driver & installs it. If it either finds a better driver or says you have the correct driver & still doesn't work you have a physical problem with the wifi adapter on the mother board. then you need to use a USB wifi adapter like this one. rt click & open in a new tab to view
Trendnet N150 Mini USB Wireless Adapter - IEEE 802.11b/g/n, 2.412 ~ 2.484GHz, 150Mbps, WPS, USB 2.0 (T156-2502) 1 $9.99 $9.99
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Oct 04, 2014 | Toshiba Satellite Computers & Internet
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Laptop HP 4520s I5 - I pushed the button off laptop, and now it does not start, remain stuck in start
unplug ,remove battery, try a sewing needle or straight pin to work around the button to clear any obstruction. Use a LITTLE Silicon Spray to free the button, spray into a cap and maybe apply with a Qtip or toothpick.
Jan 20, 2013 | HP Computers & Internet
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
My bobbin is stuck on my viking computer 400, broke one bobbin and wasted all the thread - put another on and it is full again - stuck...released the needle and that didn't work either...using expensive...
Did you get solution yet? More than likely you have bad bobbins. Their probably old and maybe cracked. They usually stick on the winder when they get old. Try some new ones.
Apr 17, 2011 | Husqvarna Viking 1
My car wont go into gear, and i found a thick rubber part on the ground . its Round and it appears to have broken off clean
you relly need to repost you question and give more detail, such as, do you mean that the shifter wont move or do you mean that you can put shifter in the desired gear and nothing happens, i would relly like to help but a little more info would help me do that
Jan 10, 2011 | 1998 Saturn SL
Theres a little ball stuck in my iphone 3gs headphone jack.can anybody help me.how do i get it out?
Get a round toothpick, break off the sharp end and put a small dab of "Crazy Glue" on the end of the cut off toothpick.
Then insert the toothpick into the head phone jack hole till it touchs the ball, wait approximatly 1 minute and pull the toothpick with the ball out of the head phone jack.
Be sure not to touch the sides of the head phone jack hole with the "Crazy Glue" .
Good luck, I hope this helped
Please rate me, Thank you
May 11, 2010 | Audio Players & Recorders
Car won't start and dash light flickers
Sounds like bad connection at battery. Remove the battery connections, clean the battery posts with a wire brush, and reconnect battery. Make sure connections are tight.
Jun 03, 2009 | 1999 Acura TL
Jazzdv179
what are u relly trying to do puta pic on a web cam to show sum one ? most web cams u cant upload imagae to it like that send pic directto pp
Jan 30, 2008 | Photography
Video Cameras Logo
54 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
