Question about Garden
My sthil saw ts410 pull cord just pulls out freely and retracts but doesnt start the saw
Check for loose plug or blown head gasket, or the mechanism inside that spins the motor, the gear may be broken, or the key way has snapped.
Posted on Nov 28, 2014
    Champion:
  • 225 Answers
Either the starter pawl on the pulley has stuck or is worn out.
My sthil fs 310 trimmer
Determine whether or not the engine is locked up by removing the plastic outer shell including the pull cable. The cable reel once dis-engaged from the crankshaft should freely pull out and retract on its own. If the cable reel is still hard to pull, you can replace the reel. Otherwise the engine is binding probably cheaper to replace the whole unit than attempting repair.
May 14, 2014 | Saws
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
I have a Husqvarna 455 Rancher chainsaw with a 20"
Part of the cord must of got into the clutch if its not the retracting mechanisem or spring you are on the right track. The olny question i have is if its a 2007 why did the cord fail so quickly. rebuild it you will find the answer I can't see it and you sound vary capabale of fixing this
Dec 19, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Problems with pull cord ,pull cord not engageing,pull cord is slipping freely.it acts like a bad spring on a briggs,but iam not familiar with this make.
Pull cords are all pretty similar so if you've seen one then etc.....
Does the cord retract?
If it's a broken spring then the pull cord would not retract.
If it is retracting then it's probably dirt, grass clipping interfering with the spring loaded locking lever.
Either way the only way to be sure is to remove the top cover and inspect it visually and clean it out and spray some lubrication on it.
You should be able to do this without taking apart the actual cord and retracting coil spring. It should come off as a unit.
Once you have inspected it if you you have any other questions please let me know.
Hope this helps.
Jun 16, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Husqvarna pull cord problem
I had this happen after about 15 uses. I just exchanged the unit. The pull start mechanism can be ordered and is easy to replace. There are parts inside that are nylon and break easily. Any local dealer can order the part for you.
Dan
May 03, 2010 | Husqvarna 28cc Gas Line Trimmer
Filling carb up with fuel
this sounds likke the float is sticking
Sep 08, 2009 | Saws
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
