Question about Garden
Starting cable pulls out and retracts with out starting the my sthil ts410 what could be wrong?
  • 294 Answers
Faulty sprag clutch on the starter.
Posted on Nov 28, 2014
Sthil ts410 fitted new barrel &piston runs ok till air filter housing is on ok with just filter till plastic housing is on all air ways to housing have been stripped and cleaned
check that the gasket to the barrel is installed correctly and not upside down blocking of an air hole to the carby
the problem is that the fuel level is excessive causing flooding when the filter is fitted
that is normally from lack of control to the carby diaphragm from blockage or vacuum hole problem
if you have reconditioned the carby , check the way the diaphragm has been fitted in relation to the gasket
Jun 23, 2016 | Garden
My sthil fs 310 trimmer
Determine whether or not the engine is locked up by removing the plastic outer shell including the pull cable. The cable reel once dis-engaged from the crankshaft should freely pull out and retract on its own. If the cable reel is still hard to pull, you can replace the reel. Otherwise the engine is binding probably cheaper to replace the whole unit than attempting repair.
May 14, 2014 | Saws
Trottle cable on sthil 45z hedge trimmer too loose
The outer cable is probably not fixed in place at the bottom end. If so, instead of the control moving the inner cable and moving the air control butterfly, the outer cable is sliding down the inner cable and so no movement of the inner cable occurs. Look for a missing or loose outer cable clamp.
Jan 26, 2014 | Echo Garden
I have a sthil ts410 disc cutter changing piston but can't get old piston out
Did you try WD40 or Q20, depending if you are in the UK or SA?
Oct 05, 2013 | Cars & Trucks
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
How to fix a retractable winding for the start cord on a sthil weed eater. cord is hanging out and will not retract back in.
Have never worked on a Stihl, but it's evident ..you are going to have to remove all the covers to get to the recoil unit itself and when you get there, you will see the problem. Don't know what kind of fasteners Stihl uses on their equipment, but the cheaper manufacturers use TORX screws in their applications.
Jul 18, 2010 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
