Question about Schwinn Cycling
What is the output voltage, amperage, watts and polarity for Schwinn 203 recumbent bike? I have a pile of transformers and don't know which one my mother-in-law used. Thanks for all replies.
Don't want to use the wrong one and blow out a board.
    Sniper:
  • 73 Answers
If the recumbent digital computer gives you an option of power supply or batteries then you can deduce voltage of the power supply by counting the number of batteries needed times 1.5 (1.5 volts = voltage of AA or AAA battery).
You can deduce typical current by multiplying the number of batteries by: AA = .05 amps or AAA = .01 amps.
Your next issue will be to deduce the polarity. Look at the Schwinn to look for a symbol that will show you polarity. Typically the center of the plug is: + positive and the outer shell is - negative. There are instances where those two are reversed.
If this is all too confusing then Google the recumbent model number to find replacement power supplies ($35 to $45 US).
Posted on Nov 28, 2014
Testimonial: "No battery option. no symbol for polarity on plugin. If anyone has the correct transformer, all they have to do is look on the transformer, all the info will be there."
My Scwinn excercise recumbant 203 bike start/stop is not working. Can I get a replacement?
Scott, If you do not see your part listed in link below, you may want to try a small electronics/computer repair shop they have ways to repair these items. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.fitnessrepairparts.com/diagram/6529
http://download.nautilus.com/supportdocs/AM/Schwinn/SCH_201-203_AM_web.pdf
http://www.sportsmith.net/productsearch.aspx?dsNav=N:10547
Jul 28, 2016 | Exercise & Fitness
How can i get a power cord for my Swinn ex. bike?Estimated to be 5 Years old.
It would help to know what model bike You have because that model number can be given to any appliance parts dealer that You find locally, possibly even Sears, to get a replacement power adapter. I'm assuming Yours is like a small transformer that plugs into the wall outlet with a small cord that has a shiny metal pin on the end that plugs into Your Bike? Adapters for other Schwinn® and Nautilus® home fitness equipment can be ordered by phone at (800) 605-3369. Optional power adapter for the Schwinn® A40 elliptical, A10 and A15 upright bikes and A20 and A25 recumbent bikes. I hope that helps!
Feb 19, 2015 | Power Motorcycles
E-1 massage on Schwinn Bio Dyne 150
1) adjust the speed sensor, clean it and tigh the wires connector see the diagram.
2) test the input voltage motor, if there are the motor need repair
3) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jul 27, 2012 | Schwinn 250 Recumbent Bike
The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
We have a lutron nova 2003p (1600 watt) switch supplying power to a line of 18 12 volt, 50 watt lamps. switch went out. is this caused by over-amperage draw?
Hi John, I'm an electrician and I think I can help you with this problem.
First and foremost, this switch's 2000VA / 1600W electrical rating is based on a incandescent load.
Let's do do the math on this one.. 18 x 50 = 900 watts. So, you're under the 1600 watt capacity, but I think this is a bit more involved than this.
I'd be willing to bet that you're not dimming a 12 volt circuit - but rather a 120 volt circuit that supplies one or more transformers that step the power down from 120 volts to the the 12 volt bulb voltage. A transformer is an inductive load. A transformer's inductive load is completely different than the incandescent load the dimmer is designed to control. The transformers are rated for 120 volts and will have issues including heat problems if provided less than the rated input voltage to provide a reduced output voltage you want so that you can dim these lights.
This switch will not work on the output of the transformer in this situation either because the significant amperage being switched here. Each of these lamps draws a bit over 4 amps as determined by ohm's law: 50W / 12V = 4.16A. The total load at 12 volts is (again, Ohm's law) 18 x 4.16A = 74.88A ! That means the wire would need to be a #4 or #2. This is about the size of the cable on your car's battery (only amperage determines conductor size - voltage determines insulation).
A dimmer on this circuit will not work unless the fixtures are changed so that no transformers are used to supply the lamps. This includes fluorescent lamps (compact or otherwise) unless the packaging specifically states that they can be used on a dimmer.
You may wish to contact Lutron Hotline at 800-523-9466 for additional help and suggestions. I hope this helps & good luck!
Mar 29, 2012 | Lutron Electrical Supplies
I'm looking for a manual for a recumbent bike,
Hi lcbir5319...
Go to the following websites for your user manual and parts list for your Schwinn 203.
Please take time to rate me thumbs up
User Manual:
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_103-203_OM_web.pdf
Parts list: http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_201-203_AM_web.pdf
Schwinn website/customer support:
http://www.schwinnfitness.com/schwinn_fitness_us/customersupport/manualsen.jsp
Sep 12, 2011 | Cycling
Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
This is where I am getting the AC parts for my 201.
Mar 21, 2009 | Cycling
Cycling Logo
139 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
