I have a Rth111 i set the thermostat to 70and it gets down to 50 degree. In the middle of the night can u help i checked all wires and their good
  • 205 Answers
SOURCE: Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Posted on Dec 28, 2007
SOURCE: Rinnai rce-606tra II -- temperature is wrong
move thermister probe higher on back of unit
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
milten1
  • 1304 Answers
SOURCE: i am installing honywell thermostat rth111/rth221
rh goes on red, this is what will provide power to the heat
rc is red if you want to power the ac unit
Posted on Oct 21, 2009
  • 20 Answers
The red does go to RC, but the yellow should go to the W terminal, in HVAC W=heat Y=Cool, so aslong as the same wire is on RC on the t-stat, and RC on the unit, and same wire to the W on the t-stat as to W on the unit it should work!
Posted on Feb 02, 2010
My oven has had three thermostats fitted recently and an oven thermometer is regestering about 50 degrees cooler. what cani do?
To get a more accurate indication, set the oven to 350 degrees. Place your thermometer on the lowest shelf, take a reading. Place it in the middle shelf, wait for it to stabilize (5 minutes or so), take a reading, place it on the top shelf, wait 5 minutes take a reading, Average out all 3 readings, the average should be close to the thermostat setting.
Feb 15, 2015 | Ovens
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
Cooler wavers between 35 and 45 degrees.....even after turning the controls to colder. Would this be the thermostat?
Probably... OK I am going to fill you in on something here that almost no one knows. The True coolers all use a thermostat that reads the coil temperature and has no idea what the box air temperature might be. They are all pretty much the same but have a few different variations. For most beverage coolers though they are getting the coil down to around 13-15 degrees and then shut off and stay off until the coil gets back up to 38-40 degrees.This means that the air temperature can be anywhere from 23 to 50 degrees at any given moment but the product temperature is going to average out in the middle. If the box is full no problem the temperature swing will not be anything like this because the product will keep the temperature more stable. If the box is empty you will need to put SOMETHING in there to help stabilize the temperature before panicking. 3 or 4 gallons of water will do. Also if you want to sleep better at night put a thermometer in a glass of water in the cooler to get a better idea what your product temperature really is and don't put too much faith in the cheap dial thermometer mounted to the outside of the box. Oh and set the dial on 5 and if that doesn't work the thermostat could be a problem... they are the weak link in these units.
Aug 28, 2013 | True T23 Refrigerator
Rth111 does not turn on when cold
too cold for batteries or they are low. Litium Ion work well in the cold but check tstat instructions for compatibility.
Jun 12, 2017 | Honeywell Programmable Thermostat Heater
Is it safe to run a Sterling gas garage heater all night with garage doors down? It is on a thermostat and is vented to the outside.
If it's operating properly, is T-Stat controlled and is properly vented to the outside, it should be safe to operate all night. I suggest that you set the Wall Thermostat no higher than 50 degrees, though.
Jan 31, 2011 | Sterling RF45 Propane Gas Heater (45,000...
My robertshaw thermostat works well in summer when using my Air conditioner. I have a heat pump. but in the winter the thermostat frequently displays "ER" during cold winter nights when the unit...
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Jan 08, 2011 | Honeywell Electronic Programmable...
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
I have a new Honeywell Round Non-Programmable Heat Only thermostat MFG # T8775A1009. I turned it down to 50 degrees. The room temp. is reading 70 degrees and heat is coming out of my baseboards. Why is...
Make sure the switches on the back of the thermostat is set for hot water heat. If you have more then 1 zone you may a stuck zone valve or a short in the wiring somewhere keeping the boiler on.
Apr 02, 2010 | Honeywell Programmable Thermostat Heater
Older model g e profile 21.5 cu ft will not cool below 50 degrees and will not freeze below 20 degrees. just sterted last night.
this could be the thermostats playing up, but i fell its most likle to be the compressor giving up the gost on you,,,and a new compressor is pricy so try turning down the thermostats first
Nov 19, 2009 | Refrigerators
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
