Question about Video Game Consoles & Games
The inputs (scart & hdmi on my celsus tv have suddenly stopped working. Nothing has changed, but now my ps3 won't come up on any ext. Was fine yesterday
    Problem Solver:
  • 15 Answers
From standby press and hold power button for 8 seconds (2nd beep). This will reset the video settings. If this doe not work, remove the battery and try again, if displays now then the HDD has a problem.
Posted on Nov 29, 2014
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
Ravege
  • 327 Answers
SOURCE: My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Posted on Aug 01, 2008
  • 7 Answers
SOURCE: AV Cable Problems for PS3
I am not completely sure that this will help you, however try doing a "factory reset".
You accomplish this by first (1) having the PS3 being off (2) hold down the power button on the front of the PS3. It will beep once when you turn it on and then a second time. When you hear it the second time, let go. See what happens.
Sometimes if you connect your consoles video a different way such as S-Video, Component or HDMI, your console remembers those settings and saves them causing many individuals to turn their console on and there is no video.
I hope this gives you somewhere to start.
Posted on Dec 30, 2008
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Feb 16, 2009 | Philips 52 In. LCD HDTV
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
New HDMI problem
my brother had this issue with his PS3, he simply went into the settings with the av cable and hooked the hdmi up at the same time and changed the settings from auto to manual.
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
Trying to connect playstation 3 to my tv having no success
For real try this:
Turn off the tv as well as the ps3 (to where the red ps3 light is on); Then just hold down the power button in the front for like 15 seconds or so, at least until you hear a beep. Then turn the Tv back on, and hopefully once you get the tv back on the correct hdmi input, you'll see that little message offering you to switch to optimum settings.
Hope it works. Did for me.
Feb 17, 2008 | JVC LT-37X776 37 in. LCD HDTV
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
32 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
