Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619
How do I get the programming code for the BE 365 if lost and rubbed off of the label on inside of lock
I have the user codes off the label they are 3915 and 9420 but the program code has been rubbed off
  • 63 Answers
SOURCE: My new lock won't accept the programing code - so
In the given situation it is better to address in service the centre of the company of the seller.
http://conditioner2009.bravehost.com/
Posted on Aug 08, 2009
  • 59 Answers
SOURCE: I have the same kind of problem
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Posted on Aug 30, 2009
Testimonial: "Yes this did the trick. I changed the programming code so long ago I could not remember it. "
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
snowghost1
  • 784 Answers
SOURCE: I lost my manual and i need the programing code to
here is the link for the install and program instructions for your schlage lock.
http://link.schlage.com/documents/lock_user_guide.pdf
c...
Posted on Feb 01, 2011
  • 963 Answers
SOURCE: Lost 6-digit programming code and
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Mar 05, 2011
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
I lost the manual and i need to reprogram the codes
There is a video on this page, showing how to change codes.
Jan 22, 2011 | Schlage Electronic Lock FE595 Plymouth or...
Lost 6-digit programming code and need to restore lock to put in another
Jan 13, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
How do I set the key pad to my on code on my schlage electronic keyless lock
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
How do I delete/add/change the codes? I lost my instructions.
Nov 27, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
I need to programming instructions for this lock. it has a keypad on it and I do not have the instructions for it.
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
This number is the programming code referenced in the information for changing the entry code.
Complete installation & programming instructions can be found here:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Nov 01, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
May 16, 2009 | Schlage Locks & Locksmithing
Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
May 02, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619 Logo
110 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
