Question about Sunheat Sh1500rc Natural Oak Infrared Heater With Remote
The switch Was taking switch out the wires came off don't know the order they should go
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Oct 18, 2015 | EDENPURE USA1000 Infrared Heater
My iheater (iH1500) seems to be missing a fusable link located in the back center of the unit. Can I get one to replace it. The unit doesn't power up.
If you believe it is not powering up because of a blown or missing fusible link, you can simply BYPASS the fusible link with a (large) piece of wire, briefly turning the power on to test the unit. If the unit powers up with the bypass wire (and it does not blow the fuse or breaker to that outlet)... leave the bypass wire there!
May 14, 2015 | IHeater 1500 Advanced Infrared Heater...
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
Nov 05, 2014 | Patio Heaters
Patio Heater Garden Sun model JDS04SS After lighting the jets all lightup but within minutes only half the jets stay alight. Is this dangerous? the heater is a couple of years old.Can it be repaired and...
Your heater needs to be cleaned & adjusted. Contact your gas supplier for information, as to do they do the service or have someone they recommend. You will probably have to bring it in.
Oct 22, 2014 | Patio Heaters
What is a thermocouple replacement for patio heater metric threads
Not sure, Most universal kits will work. Take old one with to get replcement, sometimes depends on milli-volt out put also.
Aug 17, 2014 | Patio Heaters
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
A ERR comes up on my American comfort heater
Remove power for some time and switch on after few hours , this might reset any error on the processor , if not the error could be due to fault indication of a failure within the heater, could be the infra or the element.
Oct 02, 2013 | AMERICAN COMFORT ACW0035WE 1500W Infrared...
I have 2 sunjoy G-PH001PSS, when attached to the propoane tank, th unit does not light. I do not hear any gas whe turn the control knob to the on position. When i remove the gas line from the heater the...
Greg...
The lighting PROCESS involves HOLDING that
"PRESS MODE" for QUITE a (long) WHILE...
To clear the AIR out of your fuel line...
I have seen ... Up to 5 minutes
although I believe that is excessive)...
It is MOST LIKELY your troubles are procedural.
(READ the manuals)
ELSE
Blue Rhino
is the place to START ... or SEARCH
locally on the internet...
Try (they have manuals here... also)
Blue Rhino Outdoor Gas Heaters
Hope this helps
Carnac the Magnificent
Sep 19, 2017 | Patio Heaters
Sunheat Sh1500rc Natural Oak Infrared Heater With Remote Logo
385 people viewed this question
Top Sunheat Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Lawrence Oravetz
Are you a Sunheat Patio Heater Expert? Answer questions, earn points and help others
