Question about Samsung Refrigerators
How do I keep my RF266AEPN refrigerator with twin cooling, from icing up on the right side. This is a problem that has frequently happened in the summertime , but now, it is happening in the fall. Thi
The recommended temperature for the twin cooled refrigerator is 38 degrees. The setting and actual temp are the same. There is some icing on the right side that forms inside the top two ( of three ) oval ports. The temperature of the food and drinks feel and taste warmer than 38 degrees.
  • 31 Answers
Did you check the door gasket see if it is gunked up or air is leaking on that side? Have you felt around the door see if cold air escape? If air is escape means you will get icing or frost.
Posted on Nov 28, 2014
BIKER T
  • 909 Answers
SOURCE: The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Posted on Aug 17, 2007
DOREEN1
  • 51 Answers
SOURCE: cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Posted on Jan 31, 2008
Coldcut
  • 1554 Answers
SOURCE: Fridge not cooling
evidently the fan that runs in the freezer and blows air into the main fridge has a circuit issue or the fan is frozen, but if the bulb does not work then its a circuit issue. likely on the same circuit as fan.
Posted on Mar 20, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
Oct 12, 2013 | Samsung RF266AEPN
Samsung side by side twin cool Refrigerator side not cooling
Is it freezing from the bottom up? If so check the drain is clear. If it's freezing all over, check the condenser is clean and clear and the compressor switches off when it reaches temperature. Lastly, check the door seals properly all the way round
Apr 23, 2012 | Samsung Refrigerators
Wall of ice behind plastic facia with twin cooling written on it samsung RS21WCNS
defrost system has failed look for a failed heater or termonator . and aditive defrost control these are most common . mm feed back pls ..
Dec 03, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Sidex side 26 cf... 5 yrs old... frequent water on floor under freezer... freezer temp is erratic and will seldom be below 6, but infrequently will go below 0 setting ..can not keep ice cream
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | GE Refrigerators
Whirpool refrigerator ET21PKXGN00 poor cooling refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 15, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser on Hotpoint S/S door stopped working but ice maker is making ice
could be water inlet valve in need of replacement.also cold be water filter blocked, although would only happen in an area of high mineral content.if your fridge section is lower than 0 deg c, the water holding tank may be frozen up.also if your cab is the type with twin cooling, ie has a cooling element (evaporater)
Feb 27, 2010 | Hotpoint HSS25GFP Side by Side...
FRESH FOOD COMPARTMENT ICE IS FORMING ON FAN BLADE
You may have the tempt set on too low, and possibly not enough food items inside for the fridge to properly keep. I'd set the tempt to the manufacturer settings.
Feb 02, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Our electicity went out for a couple of minutes yesterday. Ever since then, the refrigerator side of our side by side twin cooler unit has had a slow temp. increase. It's now up to 54 degrees, The...
check the compressor overlaod, it probaly is bad due to the voltage issue with the pover problem it happens frequently with this relay
Apr 21, 2008 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
