Question about Black and Decker USA Black & Decker InfraWave Countertop
My fc150 is shutting off before its supposed to if I unplug from the waas and wait awhile its ok tell I use it again
Just unplugging it
My toaster oven quit working--the led display lights up just fine but no heat. I unplugged/replugged and it worked! for awhile. Then, the same thing and the plug had no effect.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
Jun 16, 2017 | Toaster Ovens
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Power light is out and the oven doesn't heat
He calls himself an electrician ?!? LOL!!!Not very good. He could have at least checked to make sure there was continuity in the unit or opened it up and made sure there were no loose connections. As for that sustaining ticking sound, it is because of a spring loaded mechanism.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
The timer doesnt't ding, and the oven does not turn off, ever. had to unplug. i bought at xmas, and don't use for toast, only to bake like muffins, etc.
Hello :
You need to check the fuse . If the fuse is OK , then the proplem will be with the power PCB [ printed circuit board ] . You need to call for repairing if the problem is with the PCB .
regards .
please rate !
Mar 28, 2010 | Black & Decker CTO649 Toaster Oven with...
Recall: I bought a Euro Pro Convection/Toaster Oven w/Rotisserie and it caught fire today from a non-food related problem. Is there a recall on this item? There was no food in the oven and it was...
Today I was warming up a baked potato in mine it was on 350for about 20 min when I went to shut it off the nob melted right off the ovenit was so hot I could not shut it off had to unplug it and the top of the ovenwas also very hot, is there any recalls on the MODEL # TO161
Jul 11, 2009 | Toaster Ovens
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Black and Decker USA Black & Decker InfraWave Countertop Logo
43 people viewed this question
Top Black and Decker USA Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Black and Decker USA Toaster Oven Expert? Answer questions, earn points and help others
