Question about Tablets & eReaders
How can I reset PIN so that I can get back in my tablet?
You need to look up the factory reset process and follow it then update it again basically start again so all your data is gone i think most pin issues will require this event process hope your pics etc are backed up to the cloud or media!!!
Posted on Nov 28, 2014
Why did I lock myself out of my tablet?
How do I unlock my Tablet when it's locked with a pin code ...
visihow.com/How_i_unlock_my_tablet_when_its_lock_with_pin_code
I locked my tab with a pin lock and I forgot the code. ... Locked out of my Samsung Galaxy S2 i91000? .... can use, the following steps (as well as the video above) in order to help yourself to get back into your device by using a reset combination: .... Cannot get my screen on my tablet to unlock, don't remember pin number?
My Tablet has been locked and I also forgot its Google ID ...
visihow.com/I_have_locked_my_tablet_and_now_I_do_not_know_its_...
The easiest way out right now would be to reset your Tablet. Press the ... Yes ' No ' I need help. See more questions like this: I forgot my pin password on my o+ mobile ...My Android phone has been locked and it asks for Google accounts, but I don't remember which one I used. .... I've tried to break into it myself. How can I ...
Hard reset your Android phone or tablet when you forget the ...
Jan 01, 2016 | Irulu 7" 4gb Mid Google Android 2.3...
How do i factory reset my kuno tablet that i forgot all passwords to
Look for a small pin hole in case, usually says reset next to it. Use a paper clip in the hole to press reset button. Power on while momentarily holding down reset button with clip. Then power on again, should be back to factory settings. If there's no pin hole the you hold down on off the f keys while powering up. Try googling tablet name & model factory reset.
Jun 09, 2015 | Tablets & eReaders
My RCA 7" tablet will not turn on. Just cycles through the power up mode
Try a tablet reset. First check for a pin hole reset switch location along the sides or the back of the tablet. If you have one, from the off mode depress the switch with a paperclip and power on.
If no reset switch: From the off mode, press and hold the power and volume+ buttons until the tablet recycles into the reset mode. Then follow any instructions.
Apr 01, 2015 | Tablets & eReaders
How do I master reset my EM749 tablet
To reset the tablet (for example if it's frozen and won't power off), there is a small hole on the back marked 'R', near the SD Card slot. Insert a pin or small paperclip into the hole to press the reset button to reboot.
To reset the tablet to factory settings, follow the instructions in the linked PDF:
http://southerntelecom.com/emersonsupport/reset/EM749_Hard_Reset.pdf
Jan 18, 2015 | Tablets & eReaders
Will not turn on keep shutting back off, hannspree tablet
Charge unit and if a reset pin hole in cover reset unit using a small pin or needle GL
Nov 10, 2014 | Tablets & eReaders
How do i unlock my rca tablet
you can wipe it as for removing code that is not going to be possible, to reset to manufacturer settings there is a pin hole on the back push this with a pin in the hole and turn on the unit this will reset to manufacturer settings, you may still have all your stuff on there but the settings will be back to new and you will need to set them back up after.
May 13, 2014 | Tablets & eReaders
Sent incorrect model no. before. my daughter has set a pin no. password on her tablet in error. She doesn;t know what it is so now we can't access tablet. We have pressed reset button on back but no change...
Isn't this the same problem as this one?
http://www.fixya.com/support/t24390784-pin_no_set_in_error_tablet_now_access
The tablet has no PIN. It is the SIM card for 3G that needs a PIN to access the 3G service.
When you remove the SIM card, the tablet will work perfectly without asking a PIN.
I hope this helps.
May 11, 2014 | PIPO ProntoTec 7 Inch IPS Capacitive Touch...
How do i rest my next7p12tablet
there is a little pin hole on the back just below power & volume button, put a small pin into it and press the pin into that hole. that should reset the tablet. Also press power & volume buttons at the same time and should bring up the menu, hit reset. Hope that helps.
Mar 25, 2014 | Nextbook Premium Series Next7P12
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
