Question about Nokia Cell Phones
All of a sudden, my Nokia Lumina 822 doesn't seem to hold a charge very long. Do I need a new battery? The phone is only about a year old.
Charging it.
    Problem Solver:
  • 12 Answers
In cold weather the batteries will loose charge faster. You could have the battery tested to see if it is wearing out at about any battery shop
Posted on Nov 28, 2014
  • 38 Answers
Have you installed anything on it recently, some software remains running in the background and depending on what services it uses could be the cause of battery drain.
SOURCE: correct procedure for charging battery
Batteries no longer have a memory problem so charge away.  I plug mine in every night and have never had a issues.
Posted on Oct 17, 2007
  • 67 Answers
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
Posted on Dec 21, 2007
SOURCE: nokia 5200 charging but not charging
Posted on Mar 07, 2009
walesarumi
  • 6993 Answers
SOURCE: I have a Nokia E71 and the charging problem.
Have you checked the mouth of your charger? Because your charger mouth might have loose contact internally and you not knowing. But to confirm this, you have to borrow the type of your charger from a friend and test if your phone will do the same thing. And if this does not solve the problem, try loosing the phone with a phone screw driver, check if the charging port is contact the phone board well and if this did not still solve the problem, then you will have to completely change your phone charging.
Best wishes.
Posted on Nov 23, 2009
SOURCE: problem with charging nokia 5800
buy new mobile .........
Posted on Feb 28, 2010
Nokia lumia 800 won't hold charge
First you would need to check the connectors on the charge cable and if its still not charging, then do a hard reset which means totally power the device down and then power it up and then try and charge again. Your charging cable might be defective. You can remove the battery go to bottom of device, remove memory card, then use a small screwdriver. But I would first try the first two steps because removing the battery on this device would require you to dissemble the whole device
Jul 28, 2013 | Cell Phones
Nokia 5800 not holding charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 13, 2012 | Nokia 5800 XpressMusic Smartphone
How do i restore my nokia E63 that fails to start
This happened to me one time. I had to replace the battery inside the phone, I found a battery at Walmart. Sometimes some phones also have a unique battery that is also found at radio shack. You can charge a phone all you want but if the battery is old it is time to replace the battery-then you will be charging a new battery. Sidenote, also some phones last about four years and then just after fair wear and tear just go kapoot and die. It is probably your battery, try a battery first, good luck.
Sep 02, 2012 | Nokia E63 Cell Phone
Hi Mine is a iPhone 3GS 16gb it will not charge nor turn on when I hold down the on off button nothing happens but when I plug in the charger and hold the on off button it shows the charging sign which...
First Option:
Second Option:
Aug 31, 2012 | Computers & Internet
The charging point is spoilt
Charging port are not repairable, you will need to replace or change the charging port on your phone to solve the problem.
Take the phone to any local phone repairer to help you replace the charging port on your phone, the cost of replacing the charging port is very cheap. This the solution to your phone not charging.
Take care.
Aug 09, 2010 | Nokia 2330 Cell Phone
My nokia 3230 is a four year old piece and until yesterday was working fine, suddenly it got switched off and after charging only the first nokia page comes and flashes on without proceeding any further....
Its a software problem.try format first,here is the way: make sure your battery full charge,remove the battery from phone than insert back.press and hold *button, 3button, send(call) button then press and hold power on. wait for a moment till formatting appear on your display.now you may release your fingers.and let the procces done.if work your phone will back to factory setting.Good luck.
May 19, 2010 | Nokia 3230
Nokia 2285 is turning on/off by itself
It's a software issue. Take to a nokia care or repair centre for full flashing using a computer system.
Apr 23, 2017 | Nokia 2285
Phone charges automatic
the battery life has ended...
please replace it with new battery..
thankyou
Jan 06, 2009 | Nokia N70 Cellular Phone
Showing not charging display on screen when we hold for charging the mobile.
becoz dear you have wrong battery in your cell phone
get the right battery from shop and then try
if you not able to done this mated try some other ways
get universal charger and charge your battery from its
and when battery full then putt battery in yor cell phone
the battery is full
Jun 13, 2008 | Nokia 3330 Cellular Phone
Cell Phones Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
