Question about Ovens
Some weeks ago the display dimmed and on the next day it was completely dark. Except the light nothing works anymore. Pressing of the UPPER OFF or LOWER OFF buttons has no effect. There is no error co
Checked the thermal fuse, it's ok. Cleaned the ribbon cable connecting the touchpad and control board.
The display dimmed the it went out hummmm sounds the usual
could be a dry bad solders on the controller pcb...
as its now gone out...
sounds like the psu section of the controller board has failed
you can take a look around for the details or take it to a service guy who will prob just remove and replace the controller board or you can order the controller board and fit it yourself
basically you have a low voltage supply to the controller
and this switches the high voltage and fan controls of the oven so whats happened is the low voltage supply to the controller board has failed as you say it went dim this tells me that the display inverter section or its supply has failed and as the supply to the controllers sections and display inverter its safe to assume that the main low voltage supply section on the controller pcb has a problem
this is usually caused by bad capacitors that can cause other components to fails this is why a service engineer will avoid trying to repair and and will refresh the controller pcb
so.... if your up for it youll need a DVM and a diagram
other than this a new board...
Posted on Nov 28, 2014
Testimonial: "Thanks Simeon, any idea why the display doesn't show any error code? It's just dark"
5 Suggested Answers
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
EllaWatson25
  • 725 Answers
SOURCE: i replaced the control board in a double wall oven
PF simply means a power failure and simply needs to have the breaker reset to accept the new board that you replaced. There are times when you may need to replace the breaker that controls you oven electricity.
Posted on Oct 21, 2009
  • 61 Answers
SOURCE: Whirlpool Accubake RBD306PDB - Fans won't stop + codes F2 E1
yes. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper. good luck.
Posted on Oct 27, 2010
  • 5370 Answers
SOURCE: I have been trying to
you can order this part from repair clinic.com.At present this part is out of stock. ------------ click this link below:--
http://www.repairclinic.com/PartDetail/Touchpad/4451314/589799 ----------- They also mostly all types of control touch pad board. --------- This is there contact details.Just contact and get the exact detail for when the part will be in stock.also they have all types of board.Confirm if they have any compatible, or substitute board available.------ 1-800-269-2609/ open 7 days.Timing morning 7 to evening 8.
  • -------This should help.Keep updated.Thanks.Helpmech.
  • Posted on Jun 16, 2011
    The display has stopped working, the oven light works, the gas burners work.
    There may be a fuse inside the oven which has failed or it could be the electronic display board.
    Sep 18, 2015 | Ovens
    Display went out on my whirlpool RBD305 oven and then it stopped working
    You will need to replace the control board. Here is the part to order.
    The part comes with a 365 day, any part, any reason return policy.
    Nov 20, 2012 | Whirlpool RBD305PD Electric Double Oven
    I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
    Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
    Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
    I recently bought a new house with fitted kitchen containing a fitted Diplomat double oven. When the power is on but both ovens off the Amber light above the top oven mode selector glows dimly. When I...
    I'm not sure its been connected properly, needs checking out by someone who know's what they're doing. Be careful, the fuse doesn't trip for nothing.
    Jul 09, 2010 | Ovens
    Jenn-air dbl oven WW30430B. Lower oven doesn't work anymore. Try to pre-heat - get F2 message. This started a year ago. Shortly after onset we had a hurricane and were without power for 2 days. When power...
    HI. the oven control will interrupt normal actions if it senses an abnormal oven temperature. this can be caused by a faulty RTD(temp sensor), and, also, a faulty relay board if present.
    Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness to make sure it is in good condition.
    Aug 04, 2009 | Ovens
    Jenn-Air oven display blank. Only works when oven has heated up.
    I had the same problem and just fixed it myself today. Not sure if your timer board is the same but I replaced capacitor C3 35volt 68uf. I also have the dark spot on the clock glass in the corner but it still works. I purchased the cap from digikey.com P10292-ND. I also replaced the cap next to it 35volt 470uf P10301-ND not sure if that was necessary but it smelled a little burnt. The display is normal brighness again - total cost 1/2 hour of my time and $4 parts and shipping. Digi-Key is great I ordered the parts on Thursday 7/23 and got it today 7/25.
    Jul 21, 2009 | Jenn-Air Electric Double Oven
    Oven digital lighted display is dim
    You need to replace the C3 capacitor on the control board
    http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
    You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
    May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
    mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
    Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
    I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
    Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    57 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
