Question about Garden
I have a Ryobi 430 4 stroke weed wacker frozen up can not pull the string take spark plug out very easy to pull full rotation easy to pull when you pull the string put the spark plug back in you can pull it but I think when it gets to the compression stroke it's really hard to pull afraid I'm going to break the string Thanks
  • 38 Answers
When you remove the spark plug is it very wet?
after the plug is removed when you pull the cord sharply does liquid come out from the hole?
Posted on Nov 28, 2014
5 Suggested Answers
  • 3 Answers
SOURCE: How do I restring my Ryobi weed wacker
Start in the center ,snap the center in place. than put the ends out through the holes.
Posted on Jul 20, 2009
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
  • 89 Answers
SOURCE: String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Posted on Nov 05, 2009
Testimonial: "Thanks for the help. We did look at the coil. Got about 30 volts out of it when we pulled the starter. I hope that means it's OK."
SOURCE: string on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Posted on May 27, 2010
I have a Ryobi 430 4 stroke weed wacker try to start this morning seems like it was frozen up took spark plug out pull the string free flow rotates easy put spark plug back in very hard to start fraid I'm...
Paul you might want to replace the spark plug, make sure the gap on the plug is correct, make sure there is oil in the machine, some have a safety switch when the oil is low. If you cant buy a new spark plug you can sand off the tip that is probably black and replace it in the machine
Nov 28, 2014 | Garden
Help my weed wacker string
Pull the spark plug out and try pulling it over if still won't move might have seized the motor possible not enough oil in gas You can try if not to much damage done pour some kerosene or stove oil down spark plug hole let sit over night try again
Jun 08, 2013 | Garden
Weed wacker started and wacked some weeds then the strings stopped rotating but engine very strong
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
Jun 18, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
The string head does not spin as fast as the
it sounds like the centrifugal clutch is slipping. take it to several shops and get some quotes. Most times you'll find that fixing a Ryobi is more expensive than buying a bnew one.
Sep 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cant pull the rope but when you take the spark plug out the rope will pull
Sure its the correct spark plug? Sounds like the piston is coming in contact with the spark plug.
Aug 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I restring my Ryobi weed wacker I do not know which end of the string to start with?
Jul 10, 2009 | Ryobi Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you put the weed wacker "string" in mine keeps flying out when I rev it up to weed wack
You need to give close attenttion to the string wrap" arrows" or guides and see if there are holes the size of the string your using is correct size to fit into these "grip holes inside the casing.
Please rate
tk u
JJ
Mar 17, 2009 | Ryobi Garden
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
