Question about Cameras
How do you check hi limit stat on lincat fryer j10/n
    Genius:
  • 1,479 Answers
If you ask the question in the correct section, you might get the answer.
a twin tank commercial fryer is not a digital camera - unless I'm missing something.
Posted on Nov 28, 2014
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
The unit is on but does not heat up. it was working then it stopped.how do i check to see if its the thermostat or the hi limit switch
Disconnect first the unit from power source, Locate the terminals of the hi limit and thermostat then remove either one of the wire connected to it. Using an ohm meter, check for the continuity across the terminals. If the hi limit has continuity across its terminals, it is good. Thermostat will have continuity across its terminals when set to a higher temperature, you will also hear a clicking sound when its mechanical contacts engage.
May 14, 2011 | Star 301HLD Deep Fryer
My pitco 14S fryer will light but after it makes the first cycle the pilot gose out
Make sure oil temp under 400. If higher, T/stat shot. If lower, High limit shot
Aug 15, 2009 | Pitco Frialator 35CS Deep Fryer
The fryer will run for about an hour and then hi-limit shuts it down. should I replace both the thermostat and the high-limit?
Your best bet is to replace both even though the hi limit is a switch & made to be reset. Buy both & install the t-stat, keep the hi limit WHEN at the most inopertune time it decides to fail, you will be able to repair. Do not use an adjustable wrench & do not use the liquid sealer. Teflon tape for gas applications will work best & you will thank me next time you have to replace either & you wont have to get a 2 foot long cheater bar to break them loose.
Jun 04, 2009 | Pitco Frialator 35CS Deep Fryer
I have a ck20 hobart deep fryer that when plugged in and turned on, lights both lights,but does not heat.I checked both fuses with an ohm meter and they appear to be fine.Can you tell me what the...
The element will show infinite resistence if defective. Overload switch.....Do you mean High Limit T/Stat? Use your ohm meter across terminals- should read closed circuit...0 ohms. If not, push red reset button...if clicks once, is now reset and contactors will close and unit will heat. If always clicks, replace limit t/stat Like wise, check themostat--should click once for heat demand and check cicuit same as limit t/stat. May have wire burned off terminal connector at element.
Mar 30, 2009 | Hobart 1HF50D Deep Fryer
Looking for a thermostat unit for the Imperial IFS-40 serie : 05159306 what's the part number??
If you have a manual thermostat,(inside door, knob) your part is
#1175 OPERATING THERMOSTAT (HERMETICALLY SEALED REED SWITCH)
If you need the Hi-limit t-stat --
#1177 HI-LIMIT SWITCH
If you have digital control, with digital temperature control, the unit uses a probe.
#1094 FRYER CONTROLLER TEMPERATURE PROBE
Good luck, Mike
Jun 06, 2008 | Imperial IFS40 Deep Fryer
Head Banger
i havent heard of this but these suggestions may help you.the hi-limit is preset at the flash point of oil (depending on the oil) around 500-525 degrees.if the hi-limit is tripping out either the thermostat is out of calberation,the hilimit itself is bad or the hilimit/thermostat bulb arent secured to their respective bracket.if you have a meter or thermocouple tester to test the actual heat of the oil (or a half decent themometer).set the temp dial to 200 degrees,once the burners go out put the thermometer/meter into the oil.the temps should match 20 degrees over/under is acceptable.if not the t-stat is bad.if this is ok goto the hi-limit and jump it out,there should be 2 wires take them off and connect them directly.set the dial to 350,wait until the burners shut off and test the temp of the oil again.if it matches your hilimit is bad.let me know.be careful when you do this because if the t-stat is bad the oil may ignite.if you see a lot of smoke cut it off.let me know.
Jan 11, 2008 | Pitco Frialator SG14 Deep Fryer
Problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Nov 10, 2007 | Imperial IFS40 Deep Fryer
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
