When I first used the GPX tv/dvd player whenever I would turn on the tv you'd hear the dvd player doing something? Began watching dvds. Then all of a sudden the dvd player stopped working and my dvd i
I'd tried hitting all the buttons on the bottom for the dvd plus tried setup for dvd buttons on top and it always says invalid key!! If you could help me that would be wonderful as I love the tv and can't send it back coz I'm disabled.
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Try a reset to this TV. If it do not help you, contact the authorized service centre. The DVD mechanism control circuit board might have to be replaced.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 29, 2014
  • 150 Answers
SOURCE: RCA RCU403 3-Device trying to control GPX DVD player???
It may not be able to run the GPX dvd player as GPX is not a mainstream brand, if you have the original GPX remote, you might purchase a learning remote that can copy remote codes from the original, I have seen these Learning Remotes from around $20 by Phillips Magnavox if I remember correctly.
Posted on Jul 08, 2007
SOURCE: Jensen Universal Remote
HOLA NECESITO SABER COMO SE PROGRAMA EL CONTROL REMOTO UNIVERSAL JER 422 Y SU CODIGOS PARA PROGRAMAR TV DEAWOOD, SONY Y SAMSUM
ATTE.
GERARDO
Posted on May 05, 2008
  • 8 Answers
SOURCE: SAT/CBL button changes my RCA TV to channel 02
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the Manual and The Codes List!!
Enjoy!!
Posted on May 29, 2008
  • 51 Answers
SOURCE: TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Posted on Aug 06, 2008
SOURCE: akura tv dvd combo remote control codes
just got sky and need a code for the remote as i cant use the volume on it
Posted on Jul 18, 2010
I have a GPX D1816 DVD player that I would like to enable it to allow me to connect my television to the internet so that I can watch netflex televions shows.
I check GPX D1816 - DVD player Specifications but didn't see an Ethernet or wireless connection(so you can stream down video). If it did then you can use RCA/HDMI cable to connect this to a TV.
Nov 28, 2014 | GPX Televison & Video
We can't watch DVDs as it says DVD blocked for
your player probaly has something wrong with it and ur tv is telling you not to use, so buy a new dvd playeer
Dec 27, 2012 | Televison & Video
3D doesn"t work
You will need a 3D-capable or 3D Ready tv. The difference is the 3D-capable tv will require you to buy a piece of equipment called an emitter to connect to it. The 3D Ready tv already has an emitter. You will also need a 3D bluray player or Playstation 3, 3D glasses, and hdmi version 1.4 cables. You will need 3D glasses and 3D bluray Dvds. If you want to watch something besides bluray dvds you would have to subscribe to direct tv as they are now offering some 3D broadcasting.
Jun 15, 2010 | Philips DVD724AT DVD Player
I watched two movies on my brand new GPX D1816 and when I went to watch #3 the audio works but the video does not. As a matter of fact, I can hear sound, but only when the yellow video cord is not...
try to put the red (or white) cable an see what is happend, try whit movie #1or2, if is not ok you must contact the service for this apliance who is in your area.
Feb 14, 2010 | GPX D1816 DVD Player
Whenever i try to watch movie on the tv i can her
have you checked all leads?if they are all correct and undamaged check that you dont need an spif lead or yellow rca connector,then try watching on a different tv with same movie player ie dvd or video if this works there is a fault with the telly if it dosent theres a fault with your player,its a process of elimination check all componants and cross check that means tvs dvds videos and all leads.
Jul 03, 2009 | Haier Televison & Video
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Color
It could be a result of wrong broadcast system matching between the player and the TV set.
Press PAL/NTSC button in STOP mode to switch the broadcast system between PAL and NTSC.
Do you have the manual?
Jan 10, 2008 | GPX D1816 DVD Player
Aquos Turns off by itself
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, you can order the part over EBay, not hard to install just unscrew/unplug --- plug/screw..
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote Sensor
Start a DVD playing, cover the IR sensor on the DVD player with something opaque. Try changing the volume, the player should keep playing. Your TV, surround sound, and DVD player have conflicting IR codes. The DVD player probably does not use a discreet IC to filter the IR sensor, and the processor in the DVD player is having to look at all the IR codes picked up by the IR sensor. Go to Walmart or KMart and buy a new DVD player for $29.00 or stop changing the volume while watching DVDs :) Sorry, there's no real solution that I know of. Paul.
Jan 01, 2007 | Norcent Technologies DP313 DVD Player
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
