Question about Blade Saws
Was working great next day was not. When I put the wood to the blade it stops 2seconds into the wood, what's wrong?
Turning the knob on top.
  • 579 Answers
The blade may have stretched to the point where it can't be adjusted anymore. Blades get hot even going thru wood. Usually when this happens it happens in a way that puzzles you. You can try to tighten, but you may find it's time for a new blade. GOOD LUCK FRIEND.
Posted on Nov 28, 2014
2 Suggested Answers
  • 234 Answers
SOURCE: after reassembly blade will not cut wood, does not maintain suffient tension despite being correctly inserted
It sounds like the blade is not going through the guides properly if the blade is being pushed away from the wood.
Your blade is facing and moving the right direction, I am assuming.
Posted on Apr 17, 2009
Can you fix a broken control knob
Contact Black and Decker for the best info.
Putting the wrong blade in shouldn't affect the knob.
Jun 10, 2015 | Black and Decker USA Wood Cut Jig Saw...
10 inch Jet Bandsaw, cannot resaw hard woods, blade stops
if blade stops tunring then it's one of two adjustments need to be made , 1st blade tension this is set with hand screw on left side of top part ,2nd the speed of cut is too great , adjust the speed control for the hydraulic clyinder that holds top carrage to bottom , just behind the middle of unit to alllow for slower blade desent , these pistons do go bad ive replaced mine before ,
Jan 21, 2015 | Jet J-7040M 10-Inch by 16-Inch Three Phase...
How do I change the blade on a skilsaw 5250 2 1/4 hp 7 1/4 in. circular saw... there is no "locking mechanism" on this model? is this a "left-handed" bolt, Do I turn it...
Here is what you do, this is common on some skill saws, you of course make sure is unplugged, get your self a stick ( like a small broom handle type, or a piece of 1 by 2 chuck or wood, or anything of about that size. Put saw on its side, with the blade side toward you to get access to the nut to take off blade. As you know the blades go down( clockwise when operating to cut wood) and of course now, you have the problem of taking off the blade counter clockwise because the angle of the blades are going back words, ( nothing to grab on to the wood, to put a wrench on going counter clock wise to take nut off. What the idea for you and normal way is this, as the saw is on the side, with the nut/blade side toward you, you wedge the piece of wood, between the left top side of blade under the frame of the blade, meaning you are wedging it in, so the blade when turning the nut counter clockwise to unscrew, will stay in place. Think of it as wedging the blade with a chunk of wood, so it will not move. AGAIN, it comes off (nut) counter clockwise, so, you are just using this wood chunk to keep blade from moving, and then to put new blade on, just reverse procedure. Thanks Mike
Jul 26, 2011 | Garden
Instructions on removing blade from jig saw model dw933
To remove a blade on this saw, lift the knob on the top of the saw and rotate the knob counterclockwise. This will open the blade clamp. The blade should slide out. To install a blade, slide a blade in, being sure the back of the blade fit against the support roller. Clamp the blade in place by turning the knob on top of the saw clockwise until you hear a clicking sound, then push the knob down.
Hope this helps.
Apr 26, 2011 | Garden
How to change blades
unplug it. remove the bolt in the center of the blade. the blade will slip off then. a wrench for this should have come with your saw. if not, use any properly sized wrench. if needed, pull back the blade guard, put the blade on a old piece of wood, push down on the saw and use the wrench. the wood and your pressure will stop the blade from turning as you loosen the bolt
Feb 12, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Dewalt jigsaw (dw321) how to change the blade
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4".
Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once
it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller.
Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Dewalt Saws
One fan blade stopped working and is hot to touch
The motor is 'locked up' that's where the heat is coming from. It may have a bad bushing or something is jammed. Give it a good look over you may see it. Does the blade feel hard to turn?
Sep 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
PTO knob will no longer operate cutting blade
Under the hood, there is a relay switch that is taped to the fuse. In my experience, the relay has gone bad and need to be replaced.
Jun 11, 2009 | Garden
Hamilton Beach 22505 toaster info
Usually, four screws under the bottom remove the top but the toast loader lever knob is usually press fitted on. Some units have bent tabs to hold them together if screws are not used. To remove the knob, freeze the unit (to shrink the knob/lever) then place a flat piece of wood like a ruler wrapped in cloth on the housing behind the knob and use a large bladed screwdriver to try to work the knob off. If you break it superglue and epoxy, and drawer knobs not plastic or wood might work as a replacement.
Nov 05, 2007 | Hamilton Beach 22505 IntelliToast 2-Slice...
Saws Logo
50 people viewed this question
Top Blade Saws Experts
Rabbit Brains
Rabbit Brains
Are you a Blade Saw Expert? Answer questions, earn points and help others
